ᐅ Removing wood splinters from the wooden shelf and performing finishing touches.
Created on: 30 Aug 2018 19:37
GinonHello everyone, I recently bought a wooden Billy shelf from IKEA and unfortunately noticed some small wood splinters along edges and surfaces. My question is: What is the best and gentlest way to remove these splinters without damaging the surface or compromising the stability of the shelf? Additionally, it would be great if someone could share tips on how to clean up the affected areas afterwards and possibly protect them from splitting again. I prefer working with hand tools but want to avoid anything too drastic, as the shelf is already in use and should still look reasonably good. Thanks in advance for your experience and advice!
Hello Ginon,
First of all, regarding the removal of the wood splinters: I recommend carefully sanding the splinters down using a fine, sharp sandpaper (e.g., grit 180 to 220). Be sure to sand along the grain to avoid tearing out more wood fibers. If the splinters are firmly attached, a sharp craft knife or a small chisel can help precisely remove larger splinters before sanding. It’s important to take your time and work gently to avoid damaging the wood.
For follow-up work: After sanding, you can dust off the surface with a fine sponge or cloth and then apply an appropriate sealant depending on the surface. For Billy-type shelves, the wood surfaces are usually veneered or painted, so a thin layer of clear varnish or wood oil is recommended. This smooths the fibers somewhat and helps prevent further splintering.
One more question for you: Is your shelf painted or untreated? This significantly affects how it should be treated. It would also be helpful to know how severe the splintering is and where it occurs, so more specific advice can be given.
Hey Ginon, the issue with wood splinters is really frustrating, but don’t worry, there are great tips to handle it! 🙂
What I always do first is carefully remove the protruding splinters using a small fine-toothed saw or a sharp knife, applying only gentle pressure. Then, take fine-grit sandpaper (200-240 grit), preferably dampened, to smooth the surface nicely and help close the wood fibers.
Exactly! I always use a wood oil; it soaks in well and protects better, lasting much longer than paint or varnish, especially on furniture that gets touched frequently.
The most important thing is to stay calm and be patient; usually the splinters come off after a bit of careful work. You’ve got this! 🙂
benonon schrieb:
After sanding, you can dust off the area with a fine sponge or cloth and then apply a suitable finish depending on the surface.
gipifa schrieb:
I always use a wood oil that penetrates well and protects; it lasts significantly longer than a varnish, especially on furniture that you often touch.I find those endless oil treatments and constant re-oiling generally overrated. For a Billy bookshelf, which doesn’t require a high-quality surface, I think it’s perfectly fine to just remove any splinters, carefully sand with fine sandpaper, and then apply clear varnish sparingly.
Wood oils are nice for fine furniture, but for an inexpensive piece like a Billy shelf? It’s not going to last forever anyway, and who wants to keep maintaining it endlessly? In my opinion, the effort often outweighs the benefit.
Also, let’s be honest: splinters on Billy shelves are caused by the basic particleboard or veneer quality anyway. If you really care about a perfect surface, you might want to consider investing in better furniture from the start. Just my opinion 😉
