ᐅ Protecting and Properly Cleaning IKEA Metod Countertops to Prevent Scratches
Created on: 6 Aug 2023 08:24
frabar52
Hello everyone, I recently installed an IKEA Metod kitchen and encountered the issue of scratches on the countertops. Laminated countertops in particular seem to be sensitive to scratches, and I want to ensure the right protection and proper cleaning as early as possible. My question is: How do you effectively protect your IKEA Metod countertops from everyday scratches without compromising their appearance or functionality? Also, what are your experiences with the correct cleaning methods, especially regarding the materials used in Metod countertops? I am particularly interested in whether there are specific care products or techniques that do not damage the material but still clean gently and thoroughly. I look forward to practical tips, including personal experiences or manufacturer recommendations.
Regarding cleaning, I have had good experience with the following routine: Clean the countertop daily with a lightly damp microfiber cloth, preferably using only water or, if necessary, a mild dish soap solution. For stubborn stains, it helps to let dish soap sit on the affected area for 5–10 minutes and then gently wipe it off. It is important not to use harsh or abrasive cleaning agents, as they can make the surface rough.
For more intensive care, special laminate maintenance products can be used, but this is not essential if you are careful. Also, always use heat-resistant trivets or pot holders, since heat can quickly damage the surface, as has already been discussed here.
Josefane schrieb:
IKEA does not provide an exact temperature specification for Metod panels, but generally, laminate surfaces are sensitive to heat starting at around 140 degrees Celsius (284°F).That’s insightful, thank you!
I have a follow-up question to further clarify the topic of protection: How does the surface sealant on Metod countertops hold up? Is it affected by frequent cleaning or household remedies (e.g., vinegar essence or citric acid as common household agents)? In particular, it’s often said that such substances are unsuitable for natural stone or wood, but I’m unsure whether laminate or melamine countertops are also vulnerable to damage from these.
I want to avoid the finish dulling over time or invisible microcracks developing that could make the countertop more sensitive.
