Hello
I need your advice.
Two weeks ago, in a moment of madness, I insisted on oiling my parquet floor. Since my Bauwerk oil was either used up or too old, I quickly bought the Micolor parquet oil at Migros. Bad mistake... It’s sticky, stains, and looks extremely greasy. Even after cleaning it three times with a heavy-duty cleaner, which I have applied undiluted in some spots, it hasn’t improved much. Does anyone here have any advice on what I can do next? I also have a floor polishing machine. I’m wondering if I should simply go over it dry with the white polishing pad and then reapply the Bauwerk oil? Or do you have a better suggestion?
I have already contacted Migros to complain about such a poor product. But the damage is done for now...
I need your advice.
MODERATOR10 Nov 2010 11:27Hello,
It seems the product was not applied quite correctly; if the oil is sticky and greasy-looking, this indicates that too much oil was applied.
One way to fix this is to remove the excess oil using cotton cloths – if that no longer works, treat the surface again with citrus peel oil using a floor machine with green pads or polishing pads – afterwards, you can oil it again and work it in with white pads.
Hello
The oil is labeled so that one bottle should cover 20m² (215 sq ft). I oiled about 80m² (860 sq ft) using roughly 80% of a bottle, so I think I applied it very sparingly. I applied it with a floor polishing machine and tried to spread it evenly. I have oiled my floor several times before, so it shouldn’t be an issue with maneuvering. I also used the basic cleaner in its pure form, which is effective, but I am afraid to apply as much as I probably would need to really get rid of the greasy spots. There is one especially unpleasant spot that is right in the main field of view. I will now try to work on that further.
What happens if I now apply the quality construction oil on top? Will the greasy layers then be permanently polished in?
Thank you very much for your help!
MODERATOR10 Nov 2010 14:55Hello again,
if the oil was applied correctly, another possible cause could be the different composition of the oils; the existing oil does not harmonize with the new oil.
Bauwerk itself already offers different oils that do not work well together, for example their water-based Rustik oil must only be renewed using the same oil.
This could be another solution approach: to check the compatibility of the oils.
Thank you for giving this so much thought.
I believe you are absolutely right. Wood treated with Bauwerk products will not be compatible with Micolor. I will now follow this plan: as soon as I have purchased the product, I will treat the worst-affected area with the appropriate Micolor solvent. Maybe that will help. Then I will lightly pre-treat the entire floor with the white pad. After that, I will impregnate it with Bauwerk oil. I hope this will restore the usual beauty of my parquet floor.
I wish you a pleasant day!
