ᐅ Plastic handles for KALLAX units don’t hold up well – which ones do you use?
Created on: 18 Mar 2015 14:23
albionkarA
albionkar18 Mar 2015 14:23Hello everyone,
I have a rather annoying problem with the plastic handles that come with the KALLAX shelves from Ikea. I’ve noticed that these handles often break or come loose very quickly, which is really frustrating, especially with frequent use. I’m quite familiar with the KALLAX series and use it in several rooms, but I just can’t cope with the plastic handles in the long run.
So here’s my question for you:
What handles do you use on your KALLAX shelves, and which materials or brands would you recommend that are both durable and visually fitting?
It’s important to me that the new handles are not only more robust but also easy to install and don’t require too much effort.
Maybe someone has had similar experiences or has already found a solution. I’m looking forward to your tips and opinions!
albionkar schrieb:
Which handles do you use on your KALLAX shelves, and which materials or brands can you recommend that are both durable and visually suitable?I know that problem all too well! My plastic handles kept breaking too, even though I treated them carefully. I completely understand how frustrating that is, especially when you rely on Ikea’s simple solution.
What helped me were metal handles, especially stainless steel or chrome-plated ones that you can often find at hardware stores. They are a bit more expensive and require a somewhat more careful installation, but they really last much longer and usually look nicer as well.
I switched to those kinds of handles myself and can say that they are not only more robust but also give the shelving unit a more premium appearance. Of course, the installation can vary slightly depending on the model, but most of them fit well on the standard holes of the KALLAX.
I’m also curious: How often do you use the handles on your shelves? Frequent use naturally increases wear and tear. 🙂
albionkar schrieb:
Which handles do you use for your KALLAX shelves, and which materials or brands can you recommend that are both durable and visually suitable?Hello,
I would like to respond here with a brief guide on how to find and install durable handles for KALLAX, as the frequently raised issue with the original plastic handles can be quite frustrating.
1. Material choice: Metal handles made of stainless steel or zinc die-cast are generally the most durable options. Plastic often breaks, and wooden handles can warp.
2. Pay attention to dimensions: The hole spacing on KALLAX is usually 64mm or 96mm (2.5 inches or 3.8 inches), so always measure before buying! Incorrect measurements = poor fit = screws pulling out.
3. Installation tips:
- Remove old handles carefully
- Avoid drilling new holes (use existing, suitable holes)
- Use washers with screws to prevent pressure marks on the shelf
4. Appearance: Many manufacturers offer simple, modern metal handles that fit KALLAX perfectly. Examples include Griffet from Ikea (a different series), or online stores like Hornbach or OBI.
It is important to measure the holes precisely and check the screw length before ordering—otherwise the secure attachment won’t work.
In summary:
Metal handles with matching dimensions, careful installation, and washers definitely help solve the issue with poor fastening of the plastic handles. Feel free to ask more questions if needed.
Guyju schrieb:
Metal handles with the right dimensions, patient installation, and washers definitely help solve the issue of poor grip with plastic handles.Sorry, but I see it a bit differently.
Of course, you could just add more metal and industrial overengineering everywhere, but is that really the point of a piece of furniture that’s supposed to be simple, affordable, and easy to customize?
Why not just leave out handles altogether or—much better—use recessed handles? This also looks great on the KALLAX, lasts forever, and saves you the hassle.
I think the whole discussion about interchangeable plastic handles is a symptom of a product that hasn’t really provided a perfect solution. For me, the best alternative isn’t the handle itself, but simply a different handle technique—less plastic, more minimalist style.
I’m curious if anyone else here shares this perspective. ;-)
