ᐅ Planning and Building IKEA METOD Kitchen Units Ergonomically and Functionally
Created on: 10 Nov 2024 18:37
Taugustav6T
Taugustav610 Nov 2024 18:37Hello everyone,
I am currently planning to design my new kitchen using IKEA METOD kitchen units, with a strong focus on ergonomics and functionality. My question is quite specific: How do you plan and build a METOD kitchen layout to optimize workflows, ensure the correct working height, and make the most efficient use of storage space? What standards should be considered for the working height, and how can the available space be best utilized without causing discomfort during daily tasks? I already have some rough ideas, but with the wide range of modules, drawers, and fronts available, I am still missing the finer sense for the best combinations from an ergonomic perspective, especially in medium-sized kitchens (around 10 m² (108 sq ft)).
I would greatly appreciate your experiences, proven methods, and tips – everything from proper planning to special drawer systems and assembly tricks. I am also very interested in whether height systems around 90 cm (35 inches), 95 cm (37 inches), or even higher are worthwhile in practice. Thanks in advance!
Hello Taugustav6,
great question! I really appreciate when people put this much thought into it – especially with IKEA METOD, because the system is very versatile but can quickly become confusing.
Ergonomics in kitchen layouts actually start with the working height. My tip: Measure your elbow height while standing, then subtract about 5 to 10cm (2 to 4 inches) – this usually gives a good starting point for the countertop height. Go a bit higher if you do a lot of prep work standing, and a bit lower if you mostly work sitting down.
Regarding storage, drawer systems with full extension are almost always more efficient than simple cabinets with shelves. They allow better access to contents, reducing unnecessary movements and back strain. I highly recommend internal drawers with adjustable dividers – you can cleverly store pans or tall pots in there.
When planning the installation, consider using multiple modules for easier access later to corners or any appliances you might add. And honestly, if you have pebble flooring or tiles, it’s worth investing in non-slip mats under the base cabinets’ feet – this keeps everything stable and prevents scratches.
By the way, I built my METOD at 93cm (37 inches) height, which works perfectly. Anything above 95cm (37.5 inches) can get tricky because you might end up pressing down too much while working.
Hope this helps you for now! If you want, I can also share my list of the exact module combinations I used – very convenient, honestly.
I fully agree with Dilen’s comments on work height and storage but would like to focus more specifically on planning IKEA METOD kitchen units, especially from a functional perspective.
First, an important step for anyone planning on their own: Measure your kitchen very carefully, especially the ceiling height and any obstacles like windowsills or radiators. METOD offers different cabinet heights (60 cm and 80 cm (24 inches and 31.5 inches) for base cabinets), which determine the height of the countertop. Ergonomically, the best solution is usually a compromise between your personal height, the chosen countertop height, and the cabinet fronts you select.
Choosing drawers instead of doors makes sense since drawers provide easier access. Full-extension slides come standard with IKEA, but it’s important to ensure the drawers can handle heavy loads, particularly for pots and pans. I also recommend using internal pull-outs with various inserts (for cutlery, spices, lid holders) to keep things organized and improve efficiency.
Regarding work height, many people follow the so-called elbow rule, which means the countertop height should be about 5-10 cm (2-4 inches) below elbow height. METOD countertops are commonly installed between 88 and 92 cm (35-36 inches). For someone taller than 180 cm (5 ft 11 in), a height of 95 cm (37 inches) might be better, but it’s important that the cooktop and sink are installed at the same height—otherwise, the workspace looks uneven and feels less ergonomic.
For medium-sized kitchens, it’s recommended to plan storage according to functional zones, such as pantry, sink area, and cooking area. In practice, it works well to have the main workspace near the sink. When it comes to installation, careful advance planning with a floor plan is key, ideally using IKEA’s online planner or another CAD tool to avoid ordering mistakes.
Two questions for you: What are the exact dimensions of your kitchen, and do you already have specific requirements, such as integrated appliances or special comfort features (e.g., tall cabinets with internal pull-outs or pharmacy cabinets)? That way, I can provide more targeted advice.
Interesting question, Taugustav6, and I’d like to be a bit provocative here—especially when it comes to the so-called "ideal working height." Many swear by the elbow rule, but honestly: how much true ergonomic work does an average household really need?
In my opinion, some aspects are overrated. Kitchen tasks usually aren’t that demanding, and most people tend to move around rather than standing at a cutting board for hours. Of course, it’s different if someone cooks professionally every day.
I think with IKEA METOD, the focus should be on flexibility rather than getting caught up in details that no one really pays attention to in the long run. Instead of rigid work heights, I’d recommend adjustable components—possibly even height-adjustable countertops or modular systems that can be adapted to future changes.
Also, I believe storage concepts shouldn’t be overloaded. I prefer a small, well-organized drawer over ten half-empty cabinets. My advice: plan not only what is ergonomically possible but also apply common sense.
What do you think? How much effort is too much when remodeling a kitchen?
Maybe it’s even better to allow for small flexible changes later on instead of blindly following all the standard rules now.
