ᐅ Is it advisable to securely screw the KALLAX back panel in place?
Created on: 28 Aug 2024 09:17
Pierresu
Hello everyone, I am currently considering adding a fixed back panel to my IKEA KALLAX shelves and wondering if it really makes sense. My idea is to increase the stability of the shelf and prevent bending or warping, especially when it is loaded with heavier items. On the other hand, I am concerned that this might make assembly or future adjustments more difficult, and whether it could potentially damage the shelf or cause other disadvantages. Does anyone have experience with this or can offer advice on whether it is generally beneficial to use a fixed back panel for KALLAX shelves, or if it is better to stick with the original, simply slotted-in back panels? Thanks in advance!
Nabla64
29 Aug 2024 11:29
If you are really looking for a middle ground, you might consider detachable solutions using brackets and screws, where the back panel is screwed in but can be removed in a modular way.
For example, small brackets mounted on the inside allow you to simply unscrew the back panel when needed, without completely damaging it. Important: pre-drill and insert screws carefully to avoid material breakage.
This method is a bit more complex but avoids problems with permanent drill holes or splinters while still providing the desired stability.
gregto
30 Aug 2024 08:54
Very good tip from Nabla64. That's how I solved it for a shelf that I move around often. The back panel is fixed but can be quickly unscrewed when needed.
This way, you get stability without the disadvantage of a permanent installation.
Pierresu
30 Aug 2024 10:27
Here is a summary:
- Solidly screwed back panels significantly increase stability.
- Not recommended for frequent use or moves due to disassembly difficulties.
- Removable screws with brackets or similar fixtures are a good compromise.
- Original back panels only provide limited stability.
Thanks to everyone who contributed with their experiences and helpful tips!
INGRID34
30 Aug 2024 14:42
I can only recommend firmly screwing the back panels in place if you have a lot of weight. Moving the unit then becomes a bit more complicated, but the shelf will be more stable.
Important: Use screws that are not too long and always pre-drill.
