ᐅ Is it advisable to securely screw the KALLAX back panel in place?
Created on: 28 Aug 2024 09:17
Pierresu
Hello everyone, I am currently considering adding a fixed back panel to my IKEA KALLAX shelves and wondering if it really makes sense. My idea is to increase the stability of the shelf and prevent bending or warping, especially when it is loaded with heavier items. On the other hand, I am concerned that this might make assembly or future adjustments more difficult, and whether it could potentially damage the shelf or cause other disadvantages. Does anyone have experience with this or can offer advice on whether it is generally beneficial to use a fixed back panel for KALLAX shelves, or if it is better to stick with the original, simply slotted-in back panels? Thanks in advance!
Maria35
28 Aug 2024 12:48
I see the matter quite objectively: The decision to use a fixed screwed back panel depends on the intended use. For light to moderate loads, the original back panel is sufficient. For heavy loads or frequent use as a room divider or freestanding shelf, the piece of furniture gains significant stiffening with a screwed back panel. However, one should consider that disassembly becomes more difficult afterward. So, it is less flexible for moves or changes in the living space. It is recommended for permanent installations.
gregto
28 Aug 2024 13:13
I would also say: If you mainly use the shelf for decorative purposes and don’t load it heavily, the original back panel is completely sufficient. It can also be quickly removed and reinstalled if you need to rearrange things.
However, if you regularly store books or heavy binders, a screwed-in back panel is a good investment. It simply makes the piece of furniture much more stable.
Pierresu
28 Aug 2024 13:49
Thank you for the feedback so far!
I actually plan to load the shelf partially with heavier books and collectibles. The note about limitations regarding possible disassembly is important to me. I rent my home and move occasionally. How problematic is the rear fastening when taking it down again? Financially, I consider the effort and possible additional costs for repairs when relocating as relevant.
The method presented by Nabla64 using thin plywood also sounds well thought out. Does anyone use special accessories or tricks if a shelf is moved frequently but should remain stable?
KAULIS
28 Aug 2024 14:25
A firmly screwed back panel cannot be removed as easily as an inserted KALLAX panel. Removing the screws and then using the back panel as an insert can be inconvenient because holes remain. For moves, I recommend using sturdy back panels with screw hooks or clip mechanisms instead. This maintains stability without significantly limiting flexibility.
Dustin
28 Aug 2024 15:02
For relocations, it is better to avoid a fixed screwed back panel. Stability versus flexibility needs to be balanced.
Pierresu
29 Aug 2024 09:11
Your insights on stability versus flexibility are very helpful, thank you!
I will now probably opt for a back-friendly fastening method that can be removed more easily to allow for greater flexibility. I want to avoid the risk of drill holes and damage to the shelving, especially with rental furniture.
Nevertheless, I will continue to look into this topic, so if anyone has more ideas or product examples, please share!
