ᐅ Oiled Wooden Front Door – What Are Your Experiences?
Created on: 27 May 2018 22:58
krischaaan
krischaaan
27 May 2018 22:58
we want to install a wooden front door with a sidelight...
The exterior surface of the door leaf should be oiled, while the frame should be painted.
Do you have any experience with oiled doors? Maintenance? Wear and tear?
Thanks! Good luck
Nordlys
28 May 2018 10:06
Yes, I have had consistently positive experiences with three products regarding durability, especially under UV exposure (oil durability, varnish always lasts longer):
Le Tonkinois, a turpentine oil from France, very good.
Owatrol, an oil from Norway based on tung oil, very good.
Epifanes, a hardwood varnish oil with a slight gloss, probably the best, from the Netherlands, also turpentine-based.
All of these can be found through marine suppliers and are also easily found via Google. Application: Please follow the instructions on the container exactly, and do not deviate!
krischaaan
28 May 2018 10:14
Thank you for the response.
Can I use the oils on every front door, or do I need to consider how the manufacturer treated the wood?
Nordlys
28 May 2018 10:17
All three oils are compatible with woodworking products and have significantly better UV resistance. They are also hardly more expensive. The only downside is that they dry very slowly. This is not ideal for people who buy roll-out turf because they don’t have time to wait for grass to grow.
M.c East8 Jun 2018 22:45
I didn't know that Owatrol also has products for wood. I have used Owatrol before to restore rusty studs on the underside of cars, for example on sill covers, heat shields along the exhaust, or on suspension parts.
Nordlys
9 Jun 2018 11:07
The oil is always the same, whether used as a CIP primer with some lead oxide for steel or pure for wood.
