ᐅ My pet keeps scratching the door seals of my KALLAX unit – any alternatives?
Created on: 30 Jan 2020 08:17
Ilirjan
Hello everyone, I have a small problem with my pet, specifically my tomcat. He constantly scratches the door seals of my KALLAX shelves, which I use as room dividers and storage. The seals are made of a soft rubber or plastic material and already look quite worn out. I have tried several common deterrent methods, but so far with little success.
My question is: Are there suitable alternatives or materials that are more durable or somehow "pet-resistant"? Or do you have any effective tricks to prevent scratching on such sensitive areas? I would like to avoid having to replace the entire seal every six months if possible. Thank you in advance for any tips!
dijan
31 Jan 2020 09:22
Hey, this is really a classic cat issue! 😄
I had the same problem with my couch once, and a friend recommended securing the edges or seams with double-sided tape and then applying a coarse jute or sisal wallpaper. The advantage is that your cat has a different surface to scratch that they enjoy. Plus, jute is durable enough that claws won’t penetrate deeply.
Maybe not 100% stylish, but it’s a great solution to protect your furniture from cats – and you can always adjust the color to match your decor.
keelko
31 Jan 2020 12:37
One more tip: Cats dislike sticky surfaces. You might consider sealing the door seals with a thin layer of clear nail polish or metallic paint—apply just a thin coat to harden the surface.
Make sure, however, that nothing harmful to your pet is used! Alternatively, natural sprays with bittering agents, available from specialty stores, can also help.
And don’t forget: a sturdy scratching post or mat nearby is always a good idea to give cats a place to scratch their claws.
GLALEO
1 Feb 2020 08:16
Ilirjan schrieb:
GLALEO, I’ll remember your idea about the protective film. Where did you buy it? Do you have a specific brand in mind? I don’t want it to look too thick or peel off.
Hi Ilirjan, I ordered the films online from a supplier specializing in window and furniture films, called "ClearShield." They are designed specifically for scratch and wear protection – very thin, almost invisible! 🙂 Just cut to size and apply with some water and dish soap, then press out any bubbles. The durability is really great!
Maybe you can find something similar at stores like Hornbach or Obi by searching for “self-adhesive transparent protective film.”
And remember: be patient with your cat – it takes time to get used to it.
Garry
1 Feb 2020 13:43
In summary, I would recommend the following approach:
1. Use robust and durable door seals made of silicone or specialized, harder plastics.
2. Apply protective films from the automotive glass or furniture sector as additional mechanical protection.
3. Use scent-based deterrents such as citrus oils or bitter sprays as a short-term solution.
4. Provide scratching areas nearby to redirect scratching behavior in a targeted way.
All materials should be non-toxic and compatible with the surrounding surfaces.
