ᐅ My Kallax shelf has streaks after being treated with furniture wax – any tips?
Created on: 3 Sep 2022 10:17
U
USKELO
U
USKELO
3 Sep 2022 10:17
I recently treated my Kallax shelf with furniture wax to protect the surface and enhance its appearance. Unfortunately, since applying the wax, unpleasant streaks have become visible, which significantly disrupt the uniform look. The streaks mostly run lengthwise, sometimes appear lighter than the rest, and especially occur where I applied the wax. I spread the wax relatively thinly and evenly using a soft cloth, but the result is unfortunately unsatisfactory.
Does anyone have any idea what might have gone wrong here or how to remove these unattractive streaks? Has anyone had experience with furniture wax on Kallax furniture and can offer tips for a clean and even application? I would prefer to avoid sanding the entire shelf again and am hoping for a practical and quick solution.
Thank you in advance for your help!
Siflo
3 Sep 2022 15:27
Streaks after applying furniture wax often result from uneven application or residue that was not properly spread. It is important to apply the wax thinly and with consistent pressure. After application, let the wax absorb for a few minutes, then thoroughly polish it with a clean cloth to remove any excess material.
One way to improve the finish is to gently re-polish the affected areas using a lint-free cotton cloth or to treat them with fine steel wool (grade 0000) to help distribute the wax more evenly.
Since the Kallax is usually made of lacquered particleboard, abrasion or aggressive treatment should be avoided. Generally, furniture wax works better on lightly sanded or not perfectly smooth surfaces. If necessary, the surface should be lightly sanded before waxing to improve adhesion and distribution of the wax.
If the streaks are too strong, you can try smoothing the surface with a special furniture wax or polish. Otherwise, the only option may be to remove the wax and reapply it.
klo40
4 Sep 2022 09:03
I can offer a structured approach on how to remove streaks caused by furniture wax on a Kallax:
1. Surface check: Kallax is usually melamine-coated or lacquered. Furniture wax typically only adheres superficially. Streaks often appear because the wax has not been evenly absorbed.
2. Polishing: Use a clean, soft cotton cloth or microfiber—avoid synthetic materials! Polish the streaks in circular motions. Often they will blend away quickly.
3. Fine steel wool: If that doesn’t help, use 0000-grade steel wool and gently work the affected areas. Be careful not to rub too hard. The steel wool helps break up wax residues for better distribution.
4. Wax removal: If the streaks persist, use a wax and oil remover product designed specifically for lacquered furniture surfaces. Allow it to dry thoroughly!
5. Reapplication: Once the shelf is evenly clean again, apply furniture wax thinly, preferably with a sponge or special pad. Never apply thick layers!
6. Finishing: Always polish thoroughly afterward.
Common mistakes include applying too much wax and removing it too quickly, which causes uneven distribution.
Siflo schrieb:
After applying, the wax should be allowed to settle for a few minutes and then polished thoroughly with a clean cloth
I fully agree, success depends on this.
PECLARISSA
5 Sep 2022 20:45
Oh no, that sounds really frustrating when your Kallax suddenly has those streaks – it really ruins the appearance. 🙂
From my experience, these streaks often appear when the wax is applied too quickly or too thickly. Sometimes it helps to gently rub the surface again with a soft cloth and a bit of wax remover or wood furniture cleaner before applying a very thin new layer of wax.
I recently made a similar mistake on a shelf, and after polishing in circular motions for about half an hour, I treated the surface again with some heat (a hairdryer on a low setting) – this softened the wax slightly, so I could polish again and the streaks disappeared!
Maybe you could try that, just be careful with the hairdryer to avoid any damage 🙂 If you plan to rework it anyway, I recommend working in small sections next time to keep better control.
Good luck, and feel free to let us know if it worked for you! 😎
