ᐅ My Kallax unit is nearly impossible to move after laying the carpet – what can I do?
Created on: 15 Aug 2024 08:27
BROOKSRO
I recently encountered a small problem with my Ikea Kallax shelf. After installing a new carpet under the shelf, it has become very difficult to move, even though I was able to slide it easily before. I made sure the carpet is not too thick (about 5mm (0.2 inches)), but the friction resistance seems to have increased significantly.
My questions to the community: What practical solutions are there to make the Kallax easier to move despite the carpet? Should I use special feet, add casters, or are there other tricks to reduce the movement resistance on carpeted floors?
Thank you in advance for your recommendations and experiences!
benon
17 Aug 2024 10:05
BROOKSRO schrieb:
Is there a specific type of rubber wheels you would recommend?
And regarding your question: Look for wheels with ball-bearing axles, as they make rolling easier and ensure long-term low maintenance. Rubber wheels are also gentler on the carpet.
dijan schrieb:
Wheels with a 30 kg (66 lbs) load capacity initially sound a bit excessive
That is actually not excessive. It’s better to have a slightly higher load capacity than too low, so you can easily transport additional items or heavier objects without problems.
In general: Wheels with sufficient load capacity and rubber coating as well as simple installation are the best solution to compensate for a fixed carpet under a Kallax. If you don’t move the shelf very often, you can also just install wheels on the front feet and leave gliders on the back.
I hope this helps!
