ᐅ My Kallax unit is nearly impossible to move after laying the carpet – what can I do?
Created on: 15 Aug 2024 08:27
BROOKSROHello everyone,
I recently encountered a small problem with my Ikea Kallax shelf. After installing a new carpet under the shelf, it has become very difficult to move, even though I was able to slide it easily before. I made sure the carpet is not too thick (about 5mm (0.2 inches)), but the friction resistance seems to have increased significantly.
My questions to the community: What practical solutions are there to make the Kallax easier to move despite the carpet? Should I use special feet, add casters, or are there other tricks to reduce the movement resistance on carpeted floors?
Thank you in advance for your recommendations and experiences!
Hi,
The easiest option is furniture casters that you screw onto the legs. Casters with rubber treads are ideal for carpets, as they grip better and protect the floor. Alternatively, there are special furniture sliders that work on carpet, but casters are usually easier to move.
I would like to provide a brief guide so you can weigh the options step by step and find what works best for you:
1. Identify the cause: The main reason is that the carpet increases friction between the floor and the shelf base.
2. Check furniture gliders: Plastic gliders, often placed under furniture, work well on smooth floors but are less effective on carpets.
3. Install casters: There are two types – hard plastic wheels (which do not roll well on carpets) and rubber wheels. The latter are better suited since they provide more grip on carpet.
4. Alternative solutions:
- Place a thin plywood board under the shelf to bridge the carpeted area.
- Replace felt gliders with special carpet gliders.
Summary: For easy movement, I recommend rubber wheels or creating a base that bridges the carpet. Hard plastic wheels are often unsatisfactory on carpets.
Nabla64 schrieb:
For easier moving, I recommend using rubber wheels or creating a base that bridges over the carpet.Thank you for the detailed explanation! Is there a specific type of rubber wheels you would recommend? Should I pay attention to the load capacity, or is a standard set sufficient for a Kallax loaded with around 20-25 kg (44-55 lbs)?
You also mentioned the plywood – isn’t that a bit too advanced for someone who wants to keep the shelf flexible and easy to move within the apartment?
I’m curious to hear more opinions about the caster wheels.
In addition to the previous suggestions:
1. Load capacity: For a Kallax shelf loaded with about 20-25 kg (44-55 lbs), casters with a minimum load capacity of 30 kg (66 lbs) per wheel should be sufficient, as the weight is distributed across all wheels.
2. Type of wheels: Elastic rubber wheels are ideal for carpet because they do not damage the carpet and make rolling easier.
3. Installation: Ensure that the casters have a suitable mounting bracket that can be securely attached to the Kallax without damaging the shelf.
4. Alternative: Furniture protectors or felt gliders are not effective on carpet; they usually just increase resistance.
5. Plywood board: A rigid base is very effective at reducing resistance but decreases flexibility when moving the shelf.
Conclusion: Casters with adequate load capacity and rubber coating are the most practical solution to make the shelf easy to move on carpet.
I just wanted to add: Casters with a 30 kg (66 lbs) load capacity might sound a bit excessive for a Kallax unit, but it’s better that way than having them rattle or break. 😀
Some casters also come with a locking function, in case anyone is worried about the shelf wobbling.
Moving the unit is especially tricky on carpeted floors, so wheels really make a difference there.
Oh, and don’t forget, the small rubber rings on rubber wheels can collect dirt over time, which can affect movement slightly – occasional cleaning doesn’t hurt. 😉
