ᐅ How can I securely fasten Malm furniture on carpet?
Created on: 23 Dec 2022 08:42
torianon
Hello everyone, I recently purchased some Malm furniture from IKEA that I would like to securely anchor to my carpeted floor to prevent tipping and slipping. Since the furniture is relatively tall and heavy, I want to avoid it falling over under stress, for example from children, pets, or during cleaning. My question is: what methods and tools are best suited to stabilize and safely fix Malm furniture on a soft carpet? It is important to me that the anchoring is as reversible as possible, does not cause large-scale damage to the carpet, and remains reliable over a longer period. Are there specific anchoring kits, clamp strips, or other techniques you would recommend? Any advice regarding potential risks or installation tips is also welcome.
SETHBLA
23 Dec 2022 16:18
Very simple: attach the tilt lock to the wall as IKEA also recommends. Use non-slip pads under the furniture feet for carpets. This way, you stay flexible and safe. Cable ducts are more of a gimmick and rarely sturdy.
kloreo
24 Dec 2022 09:44
If you want to avoid damage to the carpet, I advise against screwing the fixture to the floor. Non-slip materials and wall anchors are safe and practical. Look for extra strong anti-slip products recommended by manufacturers for carpets.
toril
24 Dec 2022 10:30
For secure attachment of Malm furniture on carpet:
1. Anchor to the wall using tipping prevention devices: essential for stability.
2. Use anti-slip pads made of rubber or silicone under the feet.
3. Never screw into the carpet or floor, as this causes damage.
4. For thick carpets, consider adjusting the furniture legs to ensure a stable footing.
This combination provides maximum safety without damaging the carpet.
KAUDRA62
24 Dec 2022 12:17
BAUEVA schrieb:
The truly secure method is, as already mentioned, anchoring the furniture to the wall using appropriate anti-tip brackets.
I completely agree. You can consider anti-slip pads as a convenient addition, but wall anchoring is the fail-safe solution. And don’t worry, anti-tip brackets are usually easy to install—sometimes even fun to do with kids at home. One more tip: if you have pets that tend to push or shake the furniture, it’s better to secure it twice. 🙂
Laukau5
25 Dec 2022 08:03
torianon schrieb:
Non-slip pads really hold well even on carpets like these
With a carpet about 15mm (0.6 inches) thick, the base is not completely unstable, as the fibers are dense. The non-slip pads usually provide additional support here. But my recommendation:
- First, check that the furniture legs rest firmly on the floor.
- Then use high-quality rubber pads with a large surface area.
- And add wall anchors as the main safety measure.
It is important that the furniture cannot tip or slide when under load. If you want to use protective coverings for the floor, there are also transparent plastic sheets that can be placed underneath to protect the carpet while increasing the contact area. However, this is a more extensive solution.
torianon
25 Dec 2022 09:15
Thanks to everyone for the diverse and clear responses! To summarize: the most important measure is securing the furniture to the wall with anti-tip brackets. Additionally, I can use non-slip pads under the furniture legs on the carpet, although their effectiveness is limited on a high-pile carpet, but they do provide some support.
I hope this will keep the Malm furniture stable and prevent damage to the carpet material. The idea of placing a plastic sheet under the furniture also sounds interesting—I will consider this option if the stability isn’t sufficient. Thanks again for all the tips and advice!
