ᐅ Malm drawers tend to tilt forward easily – how can I prevent this?
Created on: 24 Mar 2021 19:07
risime
risime
24 Mar 2021 19:07
I have an issue with my IKEA Malm dressers. The drawers tip forward slightly when I open them or even when they are only lightly loaded. This is not only inconvenient but also gives the impression that the construction may not be very sturdy. Has anyone had experience with how to permanently prevent the drawers from tipping forward? Are there mechanical upgrades, specific adjustments to the slides, or even DIY solutions that feel more stable? I would appreciate tips that are practical for everyday use and don’t require expensive special parts.
Thank you in advance!
Gregory
24 Mar 2021 19:44
risime schrieb:
The drawers in my unit tend to tilt slightly forward when I open them or even when they are lightly loaded.
This is a common issue with Malm dressers, caused by the relative height of the drawer front compared to the side panels and the load on the drawer slides.
To prevent this, I recommend:
1. Checking the drawer slides for wear or misalignment. If the slides are stretched out, they can cause the drawer to wobble more easily.
2. Installing so-called cabinet drawer dampers or tilt-stop fittings. These prevent the drawer from tilting forward too much by providing a stop mechanism.
3. Some users have found that adding small felt pads or rubber bumpers to the inside walls of the cabinet helps, so the drawer gently rests against these stops when opened.
Shorter drawer slides with full extension usually provide more stable support, as there is less leverage action.
In short: The problem can be significantly reduced by mechanical modifications.
O
onMarcos
24 Mar 2021 20:31
Gregory schrieb:
Retrofit of so-called cabinet drawer dampers or anti-tilt fittings.
Here is a brief guide for anyone considering a retrofit:
1. Remove the drawer completely and place it on a flat surface.
2. Check the drawer base and side rails for loose or missing screws.
3. Anti-tilt fittings can be found under terms like "drawer anti-tilt device" or "anti-tilt mechanism" at various online retailers.
4. Installation is typically done using self-tapping screws on the inside of the dresser and on the drawer.
5. Important: After installation, reinsert the drawer and open/close it several times to test the function.
Tip: For best results, the fittings should be mounted so that the drawer hits the stop when opened before it can tilt forward.
Many people make the mistake of mounting the anti-tilt stops too far back – this reduces their effectiveness.
BOSULE
25 Mar 2021 07:58
I would like to add that the forward tipping is also caused by the design of the Malm drawers. The fronts are relatively heavy and hinged, which can lead to tipping when the drawers are fully loaded with heavy items.
Therefore, in addition to installing anti-tilt fittings as mentioned, I recommend paying particular attention to not overloading the drawers. An even distribution of weight also helps.
risime schrieb:
Are there mechanical retrofit options, specific adjustment settings on the rails, or even DIY solutions?
Replacing them with higher-quality full-extension drawers could be a long-term solution if retrofits do not achieve the desired effect. This largely depends on the individual usage situation.
risime
25 Mar 2021 10:22
onMarcos schrieb:
You can find anti-tip fittings under terms like "drawer anti-tip" or "anti-tilt device" from various online retailers.
Thank you for the detailed instructions; they are very helpful. If I understand correctly, these anti-tip fittings provide a mechanical limit that prevents the drawer from tipping forward or sideways.
BOSULE schrieb:
The fronts are relatively heavy and hinged, which can cause issues under full load with heavy items inside the drawers.
This advice is important to me as well. I will try to adjust my loading habits and possibly store heavy items in the lower drawers of the dresser.
Question for those who have been using anti-tip fittings for a while: How durable are the installed parts in everyday use? Do they require readjustment over time, or is wear and tear a common issue?
