ᐅ MALM drawers come out of the cabinet even when secured – what can be done?
Created on: 15 Nov 2019 09:17
Martyn34
I have an issue with my Malm dressers from IKEA: despite the built-in drawer stops, the drawers sometimes come completely out when I pull them too far. It seems the stop mechanism either doesn’t engage properly or there may be a defect in the hardware. Has anyone experienced this or found a reliable way to prevent it? The main concern is to be able to open the drawers smoothly without worrying that they might suddenly fall out and possibly damage the floor.
Do you have any tips or tricks to fix this problem? Thanks for your input!
Martyn34
15 Nov 2019 13:56
Victor54 schrieb:
Has the load on the drawers been checked?
Thank you for the advice. The drawers are filled with clothing, and one drawer in particular is quite heavy. IKEA’s load limit is about 15 kilograms per drawer (33 pounds), which I have verified has not been exceeded.
I will still redistribute the weight on the drawers more evenly and monitor whether the behavior changes.
Does anyone have experience with how often these safety mechanisms actually fail in daily use? Also, does IKEA typically offer goodwill if the product is relatively new?
RETRAVIS
16 Nov 2019 08:48
Regarding the issue with the Malm drawers: the safety catch serves as a preventive measure against drawers falling out, but it is not designed as a locking mechanism.
Therefore, regular inspections and, if necessary, replacement of worn parts are required.
The safety component is made of plastic, which can become brittle over time, especially with frequent use and heavy load.
If the furniture is still under warranty, contacting IKEA is advisable. Spare parts can also be easily ordered.
As an additional measure, stopper devices can be retrofitted on the drawer slide to mechanically prevent drawers from falling out.
GiRoyce
16 Nov 2019 09:23
RETRAVIS schrieb:
The fuse component is made of plastic, which can become brittle over time
Exactly, that’s why I always try not to overload the drawers.
Martyn34 schrieb:
Are there any experiences on how often such fuses actually fail in everyday use?
From my experience, it depends on the usage, but it’s usually advisable to replace them after 2-3 years at the latest. With some patience and isopropanol, you can also clean the parts if dust is blocking the mechanism.
If you want, I can write you a guide on cleaning and replacing them—it’s really no rocket science.
It’s also best to check whether the rails are installed correctly throughout, as improper fitting can significantly affect functionality.
