ᐅ Making the Malm Nightstand Water-Resistant – Is It Possible?
Created on: 3 Feb 2023 08:17
ix_ron
ix_ron
3 Feb 2023 08:17
I want to make my Malm nightstand water-resistant and wonder if this is even possible without damaging the furniture or changing its appearance. Specifically, I am looking to protect the wood from water damage and stains caused by glasses or moisture, as I regularly place water or drinks on it. Has anyone had experience with suitable sealants or coatings for the Malm model from Ikea? Which products work well without negatively affecting the material? I would appreciate detailed tips and advice on application.
Gafiel
3 Feb 2023 10:05
Hello ix_ron,
Your idea of making the Malm nightstand water-repellent is generally feasible but requires proper preparation and the right product.
The Malm nightstand is made of coated particleboard, which is susceptible to moisture because the surface foil is durable but not waterproof. To truly protect the table from water, I recommend using a water-repellent clear coating based on polyurethane (PU varnish).
Procedure:
1. Clean and degrease the surface.
2. Lightly sand with fine sandpaper (about 220 grit) to improve adhesion.
3. Remove dust.
4. Apply at least 2 layers of PU clear varnish, allowing drying between coats and sanding lightly in between.
Important: Do not use acrylic paint or simple wood oils, as they do not penetrate the foil or particleboard well and offer little protection.
However, there is a risk that the clear coat may change the slightly matte surface to a somewhat shinier finish. This is not always a problem but should be considered.
Therefore, my advice is to test on an inconspicuous spot first!
An alternative would be special water-repellent impregnations for furniture, but these usually offer less protection against standing water and are not as durable as PU varnishes.
Have you already worked with any of these products, or would you prefer to keep it as natural as possible (i.e., no varnishes)?
Looking forward to your answer.
LEEJU
3 Feb 2023 10:42
PU varnish is the safest way to make the Malm nightstand water-resistant. Apply after light preparation, let it dry thoroughly, and you're done.
SauDietmar
3 Feb 2023 12:29
Hello ix_ron,
Here is a brief guide on how to effectively make the Malm nightstand water-resistant with minimal effort and without causing any damage:
1. Thoroughly clean the surface – no grease or dirt!
2. For this purpose, sanding is only necessary on the edges where the laminate may be slightly damaged.
3. For protection, I recommend a high-quality, thin-film polyurethane (PU) varnish specifically designed for furniture. Alternatively, a water-repellent furniture wax that does not harm the laminate is also suitable.
4. Apply the varnish or wax thinly with a sponge or brush.
5. Let it dry (at least 6-8 hours) – multiple coats will increase water resistance.
Tip: Be careful not to apply too much varnish, as this can cause the finish to become either dull or shiny, which can be annoying.
I have already protected several Malm tables this way.
One more important point: don’t forget the back and edges, as water can easily penetrate there and cause swelling.
Good luck!
karlau
3 Feb 2023 13:56
Honestly, I think it’s completely over the top to apply multiple layers of polyurethane varnish to the Malm.
Gafiel schrieb:
Therefore my tip: Test first in an inconspicuous spot!
Of course, testing is important – no question. But the Malm is an inexpensive piece of furniture. If it needs to withstand water, it’s better to buy something more durable right away or simply use coasters, right? Why bother messing around with varnishes and risk changing the appearance?
Sure, there are DIY enthusiasts who want to try every possible option. But for me, this is just overengineering. 😉
That’s how I see it.
ix_ron
3 Feb 2023 15:11
Thanks in advance for the detailed responses.
@Gafiel
Thanks for the tip about the PU varnish; that sounds reasonable. I would like to use the varnish in a way that minimally affects the appearance. How much does PU varnish change the color and texture of the surface? Is it better to apply it with a brush or roller, or is spraying the preferred method?
@karlau
I understand your point, but I don’t want to replace the table right away, and I’m not fully satisfied with coasters because sometimes a glass sweats or water spills next to it.
@SauDietmar
Thanks for pointing out the finishing of the edges and the back side; I hadn’t considered that.
Does anyone have experience with special water-repellent waxes for melamine or foil coatings? I don’t want to roughen the surface because it would become uneven.
