Hello everyone, I recently bought a Malm piece of furniture from Ikea and am wondering how to best protect it from moisture. The furniture is placed in a room that becomes somewhat humid during winter, and I want to avoid the surface swelling or warping. Are there any proven methods or products to effectively protect Malm furniture against moisture without affecting its appearance? Any tips on proper care in damp environments would also be very helpful.
Hello Piboma, thank you for your well-formulated question. Malm furniture is mostly made of particle board with a foil finish. The best protection against moisture starts with choosing the right location: avoid placing it too close to radiators or damp walls. Regarding products, special furniture waxes or oils are recommended, although the surface of Malm furniture can be sensitive. It is also advisable to wipe it with a damp, but not wet, cloth.
Using a dehumidifier in the room can help reduce condensation moisture. With regular inspection and gentle care, the furniture can last much longer. If you wish, I can provide examples of suitable products.
I’ll organize this clearly:
1. Location: Place the Malm furniture in a spot with good air circulation. Avoid direct exposure to moisture, for example from laundry.
2. Care products: Furniture waxes based on beeswax are highly suitable, as they create a protective layer that repels moisture without damaging the surface.
3. Application: Apply the wax thinly, then polish off any excess after it dries. Use only a small amount of wax to prevent stickiness.
4. Prevention: Regularly ventilating the room and keeping humidity levels ideally between 40-60% significantly contribute to the furniture’s lifespan.
In summary, I recommend focusing on a well-ventilated location and using high-quality waxes. Care requires careful attention, but with some practice, it works very well.
Jeanbar schrieb:
Malm furniture is usually made of particle board with a foil finish. That’s true, but I wonder how durable this protective foil is under consistently high humidity. Is the foil really completely waterproof, or does it eventually become porous?
Are there any reliable long-term studies on the moisture resistance of this type of furniture? It is often recommended to apply wax coatings, but I imagine that this could reduce the breathability of the furniture surface and potentially cause other issues.
Hector schrieb:
Is the membrane really completely waterproof, or does it eventually become porous? The surface of the film on Malm furniture is water-repellent but not 100% waterproof. Over time, moisture can penetrate, especially at edges and joints.
Therefore, it is recommended to additionally protect the edges with clear silicone or edge sealant for furniture.
A well-regulated indoor climate (humidity 40-60%) also helps prevent moisture stress on the material.
For maintenance, I recommend using pH-neutral cloths and avoiding harsh cleaning agents.
