Hello forum, in the ceiling of the new house there are halogen spotlights. The entire wiring is not visible. Behind each spotlight, however, there is a transformer (see picture). Two cables come out of the ceiling at each transformer, each serving as neutral (N) and live (L) – on the other side, the spotlight is connected. If I want to replace the halogen spotlights with LED spotlights, what would I need to do? Is this even possible when only the cables at the openings are visible, or could there be additional electrical installations behind the suspended ceiling that I should be aware of? Can I simply use 220V LED bulbs with the same base and connect them directly to the cables coming from the ceiling?
Thank you and best regards, Ashley
Knallkörper3 Jul 2017 20:26ashley schrieb:
Is it possible to simply use 220V LEDs with the same socket and connect them directly to the wires coming out of the wall?In principle, yes. However, if you have a dimmer, it might not work. In that case, check if the dimmer is compatible with LEDs.
toxicmolotof3 Jul 2017 21:53Probably either 220V without transformers or 12V with a transformer.
No guarantee and only after confirmation by a qualified electrician.
Knallkörper4 Jul 2017 01:07It is supposed to be connected without a transformer, right?
