ᐅ Kallax Swelled Due to High Humidity – Is It Possible to Restore It?
Created on: 9 Jul 2024 07:33
jopatrizia
I have a problem with my Ikea Kallax shelf that is located in the basement. There is currently quite high indoor humidity – I estimate around 75-80% relative humidity. I noticed that the surface of the Kallax wood has swollen noticeably in several places and also slightly warped. This makes the shelf unstable and it looks quite worn.
My question is whether this swollen MDF or particleboard of a Kallax shelf can still be saved or restored to a reasonable condition under high humidity? Or is the wood so damaged that I need to replace it or get a completely new shelf?
I would appreciate tips on how to proceed – for example, whether and how swollen wood can be dried, if sanding or painting helps, or if any special moisture protection measures are useful.
Thank you in advance!
lisku
9 Jul 2024 12:31
A wood moisture meter is a good idea.
With MDF swollen like that, you will need to sand the raised surface.
Afterwards, apply clear varnish or wood preservative.
Set up a dehumidifier and ensure the best possible ventilation.
benon
10 Jul 2024 08:15
Good morning!
Just to clarify the basics once again: Kallax is made of coated particle board. The melamine coating protects against moisture but is not waterproof. If it is damaged or not properly sealed at the edges, moisture can penetrate and cause the wood to swell.
The swelling is usually irreversible, as the wood fibers are permanently damaged. Even drying out at night only provides limited improvement and does not restore the original stability.
In your case, a repair may be reasonable if:
- The shelf has not been used for load-bearing purposes.
- Moisture levels can be reduced in the medium term.
Otherwise, the damaged board needs to be replaced or the entire shelf unit should be exchanged.
I also recommend sealing the edges with silicone or wood preservative to prevent further moisture absorption.
koduga
10 Jul 2024 09:48
jopatrizia schrieb:
Direct contact with liquid is ruled out; it seems there have been several months of high humidity.
That really sounds frustrating, especially if you love or want to keep the shelf. I had a similar problem some time ago with a cabinet in the bathroom. It caused me a lot of stress.
What I learned: patience during the drying process is key. If you have the option, placing the shelf in a drier location for an extended period will at least prevent further damage to the wood.
If that’s not possible, try to counteract as much as you can with dehumidifiers and fans. It’s unfortunate, but some damage can only be stabilized, not fully reversed.
Have you considered lightly sanding the affected areas with fine sandpaper and maybe applying a protective layer of wood wax? That can improve the appearance quite a bit, even if the structural integrity isn’t perfect.
Keep your spirits up—sometimes a bit of experimentation helps.
pikin
10 Jul 2024 11:59
Hello jopatrizia,
in addition to the previous tips: Make sure that no mold develops in the wood. Moist wood in enclosed spaces can quickly lead to mildew or mold.
One option is to coat the piece of furniture with a moisture-resistant varnish specifically designed for MDF/particleboard. This increases protection.
If possible, I also recommend sealing the edges with a sealant, as these are often the weak points when exposed to high humidity.
If the shelf is visually heavily damaged and lacks stability, it usually ends up needing replacement.
Fitigu
11 Jul 2024 07:21
That is a good tip. Special varnishes based on polyurethane or acrylic provide better protection and can reduce moisture exposure.
It is important that the surface lacquer is completely dry before application, and that the surface is clean and smooth.
Regular inspections and, if necessary, reapplication are also helpful to prevent long-term damage.
Here is another tip: measures to control humidity in the room are essential, as the furniture itself only offers limited protection against consistently high indoor humidity.
