ᐅ Kallax Swollen After Dishwasher Leak – Is Restoration Possible?
Created on: 26 Dec 2022 08:17
Tarso
I hope someone here can help me. My Kallax shelf warped due to a small leak from the dishwasher. It’s the standard piece of furniture from Ikea made of particleboard with a laminated surface, and the bottom shelf is noticeably swollen and visibly deformed from the water exposure.
My question is: How realistic is it to salvage this shelf, or should I just replace it? Are there proven methods to dry out and smooth the swollen material without having to buy a new shelf? I would appreciate any advice, including recommendations for specific repair materials or procedures.
Thanks in advance!
gregto
27 Dec 2022 07:18
Hello Tarso,
I can relate to that; I had the same problem before. Important: The material absorbs water, swells, and often can no longer hold its original shape. That’s why drying is crucial.
I recommend carefully sanding the shelf after it has dried to smooth out the swollen areas. If the surface tends to peel, you can repair it with wood glue or filler.
Alternatively, you can use thin plywood panels as a cover applied on the outside. This hides uneven spots and stabilizes the structure.
When you get a chance, check if Ikea still sells suitable shelf parts—often you can buy and replace individual shelves or side panels.
Good luck with the repair!
Ianlau
27 Dec 2022 08:41
Tarso schrieb:
Are there no repair methods that can basically “flatten out” the material again?
A certain degree of recovery is possible, but not all swollen wood-based materials can be fully restored to their original state. If you apply weight to the piece while thoroughly drying it, you can somewhat reduce minor deformations.
daalessio schrieb:
Apply repair filler to level out uneven areas.
That makes sense if you want to keep the shelf looking good. Don’t forget to seal it afterward, otherwise the surface will deteriorate again quickly.
However, for heavily swollen surfaces, this will mostly be a temporary fix.
warrenka57
28 Dec 2022 09:22
Hi Tarso,
I know the feeling when something you care about gets damaged by accident. It’s really frustrating 😕.
I wouldn’t rush to part with the shelf, especially if it still seems stable. Sometimes it helps to give the piece some time to fully dry out before calmly deciding whether to repair or replace it.
If you like, I can share my detailed advice on sanding and sealing – I’ve dealt with similar damage before and can offer some encouraging tips 🙂
NoValentin
28 Dec 2022 10:59
In most cases, replacement is the only solution. To dry, disassemble the shelf, allow air circulation, and wait 2-3 days. Sanding and sealing are only temporary fixes.
Tarso
28 Dec 2022 16:44
gregto schrieb:
Alternatively, you can use thin plywood panels as a trim
Good tip, the idea of using plywood trims sounds practical, especially if you don’t want to replace the entire shelf.
I also understand that you can’t fully restore the shelf just by letting it swell again, but if I can at least save its function and achieve an acceptable appearance, I’d be satisfied.
warrenka57 schrieb:
... first allow time to dry completely
I will definitely do that. For now, I’ve placed it in a dry spot with a fan. Thanks for the encouraging words!
I’ll keep you posted on how it progresses.
