ᐅ KALLAX shelves no longer stay securely in place after moving
Created on: 11 Oct 2015 08:47
albert-pin
Hello everyone, I have a problem with my KALLAX shelves from IKEA after moving. Previously, the shelves fit perfectly in the compartments and held firmly. After setting it up in the new location, I noticed that the shelves no longer fit tightly. They wobble a bit and sometimes even slide out if you’re not careful. In my opinion, the structure of the shelf hasn’t changed; I assembled it very carefully.
Could it be that the groove or the shelf unit itself has warped? Or is there a specific way to position the shelves to ensure they fit tightly again? I am not using screws to fix them in place, as far as I know KALLAX doesn’t require that – the shelves are simply inserted.
Has anyone else experienced something similar? Maybe you have a solution? Thanks in advance for your tips!
albert-pin schrieb:
Can this happen so quickly? Are there specific material properties of Ikea KALLAX that could cause such a reaction?KALLAX shelves are mostly made of particle board with a melamine coating. Particle board can swell slightly or warp when exposed to moisture. Fluctuations in humidity during or after transport can definitely have effects, especially on the support rails and shelves.
The melamine coating has limited flexibility; small changes in moisture or temperature can cause minimal dimensional changes. This often results in the shelves not fitting as snugly as before.
Permanent deformation is uncommon under normal use but cannot be completely ruled out.
chenlen schrieb:
Particleboard can swell slightly or warp when exposed to moisture.Additionally, when troubleshooting, it is important to measure the exact size of the shelves in comparison to the groove. Check in the millimeter range whether the width of the shelf opening has changed or if the groove of the support strips is visibly damaged or deformed.
If the shelf has been subjected to heavier load in a certain area (such as prolonged horizontal storage or stacking), slight distortions in the board can occur, making it more difficult to insert.
Small unevenness on the surface where the shelf stands can also cause it to tilt, resulting in the shelves not sitting properly.
Using a spirit level during assembly and carefully checking the angles is helpful.
pauPierce11 Oct 2015 15:37Another consideration that is sometimes overlooked: the shelf from IKEA is assembled without screwing the shelves in place. Its stability relies on the construction and precise fit. During modification or transport, slight tension can be introduced into the frame, especially if the side panels are not perfectly square or if minor twists occur.
Practically, this means the support rails may no longer be aligned parallel. In this case, I would recommend disassembling the entire shelf completely and reassembling it using a spirit level and a protractor. Pay particular attention to the assembly sequence, the tensioning elements, and the pressure applied during assembly.
This is the best way to prevent the shelves from loosening.
pauPierce schrieb:
Practically, this means the support battens may no longer be aligned parallel.Precise alignment is indeed crucial. I also recommend inspecting the support battens for damage or contamination and, if necessary, replacing or sanding them down if any unevenness hinders a proper fit.
If the shelf is placed on a slightly uneven floor, adjusting the base with felt pads under the feet could help reduce wobbling.
Midra schrieb:
If the shelf is placed on a slightly uneven floor, adding felt pads under the feet could help adjust for the floor and minimize wobbling.I completely agree! I would also try gently pressing the side panels inward by slightly lifting the shelf—sometimes it just takes a little pressure to make the boards fit perfectly. A bit of “muscle work” during assembly can work wonders. 😉
albert-pin12 Oct 2015 10:55suru61 schrieb:
A bit of "muscle work" when assembling sometimes works wonders.Thank you all for the helpful tips! I will take the shelf apart completely and pay extra attention to ensuring all sides are perfectly square. Then I’ll try to put the parts back together with light muscle effort, making sure the surface underneath is level.
After that, I will carefully inspect the support strips and possibly experiment with felt pads. I’ll report back once I have new insights. Thanks for the support and all the detailed explanations—it really helped!
