ᐅ Kallax shelves crack under load – has anyone ever filed a complaint?
Created on: 5 Feb 2019 09:12
sauken
About three months ago, I bought a Kallax shelf from IKEA and noticed that some of the shelves cracked quite easily under relatively moderate load—nothing excessive, just everyday use with some books and decorative items.
I’m curious if any of you have had similar experiences with this specific issue of shelves cracking under load?
If so, how did you handle the warranty claim? Did IKEA replace them without any problems? Are there any particular tips for assembly or use that could help reduce the risk?
I would appreciate any concrete experiences and advice, as I would like to avoid this happening to the remaining shelves as well.
ritotar
5 Feb 2019 12:43
Joe52 schrieb:
Notification deadline and proof are important
Exactly, Joe52!
And if you stay polite but firm, it usually works out quite well.
Also, I would advise you not to put any more weight on the shelves until the issue is resolved, to prevent further damage.
I’m keeping my fingers crossed for you! And if IKEA lets you down, there are surely plenty of other options here 🙂
Noahlu
5 Feb 2019 14:22
Allow me to provide a technical deep dive here:
Kallax shelves are made of MDF boards with a laminated melamine resin layer on top. While this surface looks durable, it can become brittle under concentrated and prolonged stress.
I want to emphasize that the cracking of the shelves can also be influenced by environmental factors. Temperature and humidity fluctuations in the room can cause stresses that accumulate over time.
Here are some things you should check:
1. Is the shelf unit truly placed on a level surface? Unevenness can cause localized stress.
2. Are the metal pins supporting the shelves all properly inserted and not bent?
3. Has any moisture been introduced in the area, perhaps from watering plants?
A quick question for sauken: Where is your shelf located? In the kitchen, living room, or a more humid environment?
For warranty claims: Take photos of the broken areas with a size reference. Material defects in particleboard-type furniture are a common reason for complaints at IKEA. It is important to report the issue promptly, preferably with the receipt and the shelf’s serial number.
sauken
5 Feb 2019 15:01
My shelf is in the living room, where the climate is relatively stable. There is no direct moisture, and no plants or similar items nearby.
Noahlu schrieb:
Are the metal pins that support the shelves all properly inserted and not bent?
The pins are fine, and the shelf sits firmly on them. I couldn’t detect a break exactly at those points; rather, cracks appeared across the surface and then opened up.
I also find the point about stress from temperature interesting—I hadn’t considered that, but it could indeed be a factor since the room is quite dry when heated during winter.
I will definitely start my complaint tomorrow, as you’ve addressed the key issues here.
chen67
5 Feb 2019 16:18
I have a similar issue, but with a different IKEA shelf, also related to the shelves.
I reported the problem directly at the time, and it was replaced without any trouble – but I made sure not to load it too heavily and especially avoided placing large concentrated weights on a small area.
Maybe with this type of furniture, it’s best to distribute the load more evenly?
Just an idea to help minimize the risk of further damage. 🙂
kaju67
6 Feb 2019 09:08
Hello everyone! 🙂 I also have one of those Kallax shelves, and despite careful use, I briefly wondered if such a board could really be that brittle.
sauken schrieb:
How did you proceed with the claim?
I reported my damage to IKEA online. It’s surprisingly simple – you just need to upload the original receipt along with a brief description of the damage. The process took me about a week.
Surprisingly, I can say that IKEA usually replaces the item without much hassle, as long as the damage appears reasonable and no severe misuse is suspected.
So: don’t hesitate to file a claim – if the shelf has actually cracked, you typically won’t be stuck with the costs.
Jaime
6 Feb 2019 11:27
I would like to offer a well-intentioned suggestion for your further approach:
If you want to continue using the shelf, try distributing the load over a wider surface, for example, by placing a board or a thicker base under heavy items.
Additionally, a call to IKEA might help clarify whether the weight limit was underestimated or if there is a material defect. In general, replacement procedures like this are quite standardized.
Given your problem, a production defect seems more likely. So: don’t hesitate – with the invoice number, you are in a good position.
