ᐅ Upgrading KALLAX Shelves for Heavy Loads – Where Can You Find Them?
Created on: 8 Oct 2021 08:14
Savas
I’m looking for a way to get shelves for my IKEA KALLAX unit that are specifically designed to support very heavy loads. The standard shelves are intended more for light to medium loads. However, I want to use the unit primarily for heavy books, tools, and similar heavy items, so I’m searching for retrofit shelves or another solution that will keep the unit stable and prevent sagging.
Does anyone know of suppliers or special products to upgrade KALLAX shelves for high weight capacity? Or perhaps alternative DIY ideas that are reliable and sturdy? Thanks in advance for any tips and experiences!
Savas schrieb:
Do you happen to have sources or manufacturers for more durable KALLAX shelves or at least wooden boards recommended for this purpose?There are hardly any official KALLAX alternatives. However, for custom-cut wooden boards, I recommend carpenters or online specialty wood suppliers like "Holzhandel-Deutschland" or "Plattenzuschnitt24.de," who can cut precisely to the millimeter. There, you can also order plywood or MDF in various thicknesses.
Another idea: Etsy or other DIY marketplaces sometimes have sellers offering custom-made shelf inserts specifically for KALLAX or Expedit units.
For metal frames, companies like "Metallbau Maier" or classified ads on "eBay Kleinanzeigen" offer suitable aluminum profiles that can be easily modified.
If you have the exact interior dimensions, I can also help you create a detailed order list.
BENBI schrieb:
At "Plattenzuschnitt24.de" you can order multiplex plywood panels cut to size in various wood types.Additionally: If you choose multi-layer panels, make sure they have a high-quality surface that is preferably sealed or coated to protect the wood from dust and moisture.
During installation, it is also advisable to use edge protectors on the panels to prevent fraying or splintering.
This significantly increases the durability, especially under heavy load.
I really like that you are putting so much thought into this! =)
One more tip from me: also check out the cutting service at "Hornbach" or "Bauhaus"; they often offer affordable plywood or multiplex boards cut to size, which you can take with you right away.
This can sometimes save on shipping costs, and you can check the quality in person!
Good luck!
Good luck!
Thanks to everyone for the helpful advice!
I will proceed with the tips regarding the plywood sheets and the central support, as well as ordering the cuts online.
I will get back to you once I have implemented the solution and provide feedback.
It’s great that this forum is so helpful 🙂
