ᐅ Additional Kallax Units: Will New Parts Fit with an Existing Shelf?
Created on: 24 Jul 2017 18:27
Tanlennon
Tanlennon
24 Jul 2017 18:27
Hello everyone, I have a Kallax shelving unit from Ikea’s older series and would like to purchase some new Kallax modules and inserts to expand and upgrade it. My specific question is: Do the newer Kallax components (such as new shelf inserts, drawers, doors, and boxes) fit seamlessly with an older Kallax module, especially regarding dimensions, fit, and attachment methods? Are there differences in depth, width, or hanging mechanisms that would require switching to a completely new shelving unit? I would appreciate firsthand experiences based on measurements or practical tests.
Daledra
24 Jul 2017 18:33
In short: Yes, the new Kallax parts generally fit as long as you are not using completely different series. Dimensions remain largely unchanged, but some inserts come in new colors or slightly altered materials. A complete renovation is not necessarily required.
Svenja7
24 Jul 2017 18:47
Hello! I recently updated my Kallax shelf with newer inserts as well. The basic dimensions of the Kallax unit have stayed the same for years, so newer inserts are generally compatible. However, you should keep in mind that newer doors and drawers sometimes have slightly different hinges or sliding mechanisms, which may snap in differently. This means they usually fit, but there is a small technical difference. I recommend checking the product descriptions carefully before purchasing and maybe asking in the Ikea store. 🙂
ladali
24 Jul 2017 19:05
Svenja7 schrieb:
the newer doors and drawers sometimes have slightly modified hinges or sliding mechanisms
That is correct and should not be underestimated. The original depth of a classic Kallax shelving unit is about 39 cm (15 inches), and this dimension has hardly changed. However, Ikea has occasionally introduced minor design updates in the accessories that are barely noticeable visually but can affect the precision when fitting the doors and drawers. So if you want a seamless fit, make sure to carefully check whether the product descriptions specify compatibility with your older unit.
bujufa
24 Jul 2017 19:18
Additionally, it should be noted that older shelving units may use slightly different materials, for example in the surface finish or the thickness of particle boards. As a result, hinges on new doors may not fit as precisely on older shelves as they do with fully new sets. A fairly reliable test is to measure and compare with original parts, if available.
tolokau
24 Jul 2017 19:45
Here is a brief guide on how to best check compatibility:
1. Measure your existing Kallax shelving unit precisely. Important: height, width, depth, and also the open spaces.
2. Compare these measurements with those of the new modules you want to add. Ikea usually provides such dimensions in their online store.
3. Pay special attention to the hanging fixtures and hinges, as there may be version changes.
4. If possible, test on-site at an Ikea store or ask the community online for specific part numbers.
Summary: With a little effort and accurate measurements, it usually works well without needing to replace the old shelf.
