ᐅ The Kallax longitudinal beam has a hairline crack – can it be stabilized this way?
Created on: 2 Dec 2022 08:43
Duccio
Hello everyone, I have a very specific question about the Kallax shelving unit from IKEA: I noticed that one of the long beams on my shelf has a fine hairline crack. The stability still seems intact, but of course, I’m concerned that the crack might worsen under load or with continued use. Has anyone had experience reinforcing hairline cracks in the long beams of a Kallax shelf? What methods have proven effective without damaging the overall appearance or causing further issues? Are there any specific adhesives, reinforcements, or craftsmanship tricks you would recommend? I would appreciate well-informed advice on how to safely and permanently resolve this problem, as I want the shelf to last a long time.
TRADI
3 Dec 2022 08:02
Good morning everyone, I would like to add that the use of wood adhesives with possible reinforcement always depends on the load-bearing capacity and the stress on the shelf. If possible, relieve the shelf beforehand and check whether the crack changes when moisture from the adhesive is applied. I recommend carrying out the process in several steps and, if necessary, adding a second longitudinal support as reinforcement – for example, fixing a thin wooden strip with wood glue and screws. This way, the load is distributed more evenly.
letar
3 Dec 2022 12:44
faso31 schrieb:
I am curious whether the hairline crack is really a material defect or if it could have been caused by overload.
That’s right, the cause is sometimes crucial. Kallax shelves are usually made from MDF with a veneer, which can develop cracks due to moisture or stress. If overload is the cause, reinforcement only provides limited long-term stability. A replacement part or a new unit would be preferable. Still, I consider conservative repairs useful if the shelf is not subjected to severe overloading.
Rashadmeo
4 Dec 2022 07:19
Wow, the tips here are really helpful! 🙂 I recently discovered a small crack myself and now I’m going to try epoxy resin. You don’t want to buy everything new right away if you can still save the shelf, right? Many thanks for the great advice and the encouraging atmosphere here!
bauku
4 Dec 2022 09:55
Yes, I agree! A crack like that is annoying, but definitely not the end of the shelf. With some patience, good products, and a few simple steps, it will be rock solid again! 🙂 I also think many people feel the same way – you get attached to your furniture, and repairing instead of replacing is the way to go! Maybe finish it off with a bit of wood stain, and it will even look great!
