ᐅ The Kallax longitudinal beam has a hairline crack – can it be stabilized this way?
Created on: 2 Dec 2022 08:43
Duccio
Duccio
2 Dec 2022 08:43
Hello everyone, I have a very specific question about the Kallax shelving unit from IKEA: I noticed that one of the long beams on my shelf has a fine hairline crack. The stability still seems intact, but of course, I’m concerned that the crack might worsen under load or with continued use. Has anyone had experience reinforcing hairline cracks in the long beams of a Kallax shelf? What methods have proven effective without damaging the overall appearance or causing further issues? Are there any specific adhesives, reinforcements, or craftsmanship tricks you would recommend? I would appreciate well-informed advice on how to safely and permanently resolve this problem, as I want the shelf to last a long time.
letar
2 Dec 2022 09:12
The hairline crack in the longitudinal beam of a Kallax shelf may pose a structural risk, even if its stability is not currently affected. It is important to determine the exact position of the crack: is it running across or along the beam, and how deep is it? For stabilization, two-component epoxy resin can be useful, as this adhesive withstands high loads and becomes very strong after curing. Additionally, I recommend thoroughly cleaning and roughening the area before bonding to improve adhesion. Furthermore, a thin wooden strip can be attached from the inside with screws to mechanically reinforce the beam. Important: only take action if the crack spreads or the load-bearing function visibly deteriorates.
Leland
2 Dec 2022 10:07
Adhesive: epoxy resin. Mechanical: screw a wooden batten from the inside. Roughen the surface beforehand. This ensures stability.
Alberto51
2 Dec 2022 12:25
I once had a similar crack in my Kallax. I was really worried because I use the shelf every day and didn’t want it to suddenly collapse. I reinforced it with wood glue and screws, and since then it has been stable. I just want to say: you’re not alone, and your cautious approach is definitely the right one. 🙂 Especially when furniture becomes dear to you, you want to preserve it.
faso31
2 Dec 2022 13:48
I am interested in whether the hairline crack is truly a material defect or if it could have been caused by overloading. In my opinion, a precise load analysis is hardly feasible here, but I would at least check whether the shelf is being loaded correctly. In general, mechanical reinforcements such as metal brackets could be useful, as they reduce point loads. However, additional screws can also create weak spots in the material – so proceed carefully and, if necessary, drill holes with a special wood drill bit.
loken
2 Dec 2022 15:11
Hey, I would say, don’t panic! If the crack is really just a hairline and there are no bends, often a bit of epoxy glue and minimal work with screws is enough – this can make the shelf almost like new again. You can even fill it in slightly with some wood filler, so it is barely noticeable. 😉 If you want, you can also stabilize the shelf a bit using repurposed Tetris blocks! Joking aside, sometimes simple solutions can go a long way.
