ᐅ KALLAX Load Limit Exceeded – How Can You Tell?
Created on: 16 Sep 2023 08:37
Sauvance32
Sauvance32
16 Sep 2023 08:37
I have a specific question about the load capacity of the KALLAX shelving unit from IKEA: How can you tell if the load limit of a KALLAX unit has been exceeded?
I suspect that some users only notice when the shelf is overloaded either late or when visible damage appears. For me, it is important to know what early signs or symptoms indicate an overload—such as bending, creaking, wobbling, or even cracks in the material.
Are there also differences in load capacity between the various KALLAX sizes (e.g., 2x2, 4x4)? How does an overload typically present itself in practice before irreversible damage occurs?
I would appreciate any practical advice or experiences, as I am currently planning to load the shelf heavily and want to check it beforehand without risking it being too late.
Best regards!
Jodyro
16 Sep 2023 09:01
Sauvance32 schrieb:
Which symptoms or signs indicate early overload – for example, deformation, creaking, wobbling
You usually notice it by creaking sounds or if the shelf starts to wobble. Even slight deformation under load is a warning sign. If you plan to put a lot of weight on it, make sure to follow the maximum load capacity specified in the manual.
bapar
16 Sep 2023 11:46
Sauvance32 schrieb:
Are there differences in load capacity between the various KALLAX sizes (e.g., 2x2, 4x4)?
Yes, the size and the number of shelves significantly affect the maximum load capacity. For example, a 2x2 unit has a much lower total load capacity than a 4x4 unit because there are fewer support points.
Typical signs of overloading first appear on the individual shelves: they bend noticeably. KALLAX shelves are made of pressed fiberboard, which can sag or even break under heavy load.
You should also pay attention to the joints—especially the glued and fitting connections. If the unit starts creaking or wobbling, it could be due to shifted joints that are no longer stable.
Another technical aspect is the weight distribution. If the load is concentrated in only a few compartments, it’s advisable to place the heavier items at the bottom to improve stability.
Overloading can also cause the back panel to bulge or the fasteners to loosen. In the worst case, the entire unit could tip over or collapse.
My advice: for heavy loads, consider additional supports or wall mounting, especially with larger KALLAX units.
I’m curious: how heavy exactly are the items you plan to store? Have you secured your unit to the wall?
Ramon4
17 Sep 2023 07:28
bapar schrieb:
I’m curious: How heavy exactly are the items you want to store?
Good question!
I have personal experience with the 4x4 KALLAX, where I stored books, folders, and even boxes with laundry. The shelf started to creak slightly under full load, and after several months, the shelves showed a noticeable sag of up to 2 cm (0.8 inches) in the middle.
That was a clear indicator for me: this is the limit where action is needed—either reduce the weight or reinforce the shelving.
Wall mounting is also an important point. KALLAX is basically designed for floor standing, but if the load is heavy, you should not neglect wall fastening if possible. This reduces wobbling and increases safety.
If possible, pay attention to the condition of your floor covering—an uneven surface can negatively affect load distribution.
In my case, it also helped to distribute heavy items over several shelves to reduce point loads.
And: KALLAX is not really designed for very heavy loads, so always check the material and weight specifications in advance.
U
usbla
17 Sep 2023 12:55
Sauvance32 schrieb:
For me, it is important to know which symptoms or signs indicate early overloading – for example, deformations, creaking, wobbling, or even material fractures.
From a technical perspective, you should first pay attention to the deflection of the shelves. According to IKEA, the maximum load per shelf is approximately 13 kg (29 lbs), evenly distributed. If these limits are consistently exceeded, the material, especially the particleboard, will begin to deform permanently.
Creaking can indicate loosened or stressed joints and glue connections. Slight wobbling is also a clear sign that the structure is no longer sufficiently stable.
It is advisable to place the shelving unit on a flat and solid surface and to arrange heavy loads low in the unit and evenly distributed.
Additionally, the KALLAX should be secured to the wall with the wall-mounting kit to enhance safety.
Conclusion: A combination of visible signs of aging, deformations, and audible signals are clear indicators that the load limit has been exceeded.
JONSON
18 Sep 2023 10:14
usbla schrieb:
A combination of visible signs of aging, deformations, and acoustic signals are clear indicators that the load limit has been exceeded.
I agree and would like to add: To prevent possible damage, regular inspections are recommended—at least every 6 months—especially if the shelving unit is permanently loaded with heavy items.
Checks should include not only the shelves themselves but also the fittings, edges, and the back panel.
Additionally, load testing can be useful when specific values are required. The load limits documented by IKEA consider static loads; dynamic loads caused by loading and unloading are harder to estimate.
If you want to reinforce the shelving unit, adding support strips under the shelves is advisable to prevent sagging.
In general, KALLAX is ideal for moderate loads. The specified limits should be respected to avoid long-term damage.
