ᐅ KALLAX Horizontal vs. Vertical – Which Is More Stable?
Created on: 21 Mar 2015 19:37
TAUHINRI47
I recently bought a KALLAX shelving unit from IKEA and am currently thinking about the most stable way to set it up. The question I’m wondering about is: which is actually more stable – assembling the KALLAX shelf lying horizontally or standing vertically?
Specifically, I mean which option wobbles less, stands more securely, and can support heavier items better. Some say that using it vertically is more stable because it’s designed to carry the individual compartments perfectly. Others argue that the horizontal setup works better under heavier loads since the weight is distributed.
I’m interested in arguments from both mechanical and practical perspectives. Maybe there are also experiences regarding stability when the shelf is fixed to the wall or with shelves (boards) of different thicknesses.
How have you solved this? In your experience, which setup offers truly more stability?
Looking forward to your insights!
barge
22 Mar 2015 12:48
Haha, I love it when a simple shelf suddenly turns into such a science! 😉 Jokes aside – I think the KALLAX is quite sturdy, but the vertical position has the advantage of fitting nicely snug against the wall.
From my experience with the horizontal setup, the unit tends to flex a bit under load, especially when rummaging through it or repeatedly putting weight on it.
Of course, with a thick tabletop on top and wall fastenings, it holds up well, but for regular use, I still find the vertical arrangement to be more stable.
And hey, if someone’s really adventurous, they could even convert it into a sofa substitute – but then definitely with reinforcements! 🙂
GLORIA
22 Mar 2015 14:11
After thorough examination and comparison of load point data, I can summarize the following insights:
sarpa schrieb:
The vertical positioning ensures that the individual compartments can evenly carry the load.
Indeed, the shelving system is designed for vertical load-bearing.
LOPAU schrieb:
If anyone wants a horizontal setup – for example as a tabletop or bench – I definitely recommend adding extra reinforcements.
It is advisable to use additional cross braces or stabilizing profiles, especially if the shelf will support permanent horizontal loads.
Without such measures, stresses at connection points and the thinner side walls can reduce the service life.
Guyju
22 Mar 2015 15:59
Here is a brief guide on how to check if the stability of a KALLAX shelf unit is sufficient when assembled horizontally:
1. Light load test: Lay the shelf horizontally on the floor and start by placing light items in the compartments. Check for any cracks or loud creaking noises.
2. Load increase: Gradually increase the weight and watch for any deformations or wobbling.
3. Add reinforcement: If there is any doubt, it is recommended to add brackets to the sides or place rigid wooden boards to strengthen the structure.
Be cautious with dynamic loads – loading and unloading, sitting, or jumping can quickly overload the construction.
Conclusion: Vertical assembly is more stable; horizontal assembly is possible with appropriate caution and reinforcement.
TAUHINRI47
23 Mar 2015 09:45
Many thanks to everyone for the detailed and nuanced responses!
I found the advice regarding the mechanical design of the KALLAX for vertical load especially helpful, as well as the tips on how to achieve additional stability when used horizontally.
I actually plan to use the shelf in the living room as a deep sideboard replacement, placed horizontally – with storage space on top and some heavy boxes inside.
Would you specifically recommend angle brackets in this case, or are additional wooden battens/honeycomb structures under the support surface more effective?
And are there general recommendations on the thickness of the reinforcement materials?
sarpa
23 Mar 2015 11:22
for horizontal use as a sideboard, it makes sense to combine both methods. Angle brackets (metal or wood) on the sides increase lateral stability and prevent twisting.
Additionally, cross braces or a solid wood panel below or above the surface improve load distribution. I recommend wood panels with a minimum thickness of 18 mm (0.7 inches) to reduce deformation.
It is important that the connections are securely screwed and that no load rests solely on adhesive or snap-fit joints.
This way, the structure remains durable and stable, even with heavy items.
FAZAR
24 Mar 2015 07:53
One last technical tip for reinforcement in horizontal construction:
To efficiently transfer the load to the supporting wall, make sure that the brackets used are positioned to absorb shear and tensile forces. Metal brackets with a thickness of at least 3 mm (0.12 inches) provide better stability than thin wooden strips.
At the same time, I recommend securing the top plate firmly to the base shelf over a large area using screws or wood glue to form a single unit.
If possible, also place non-slip rubber pads under the shelf to prevent it from shifting under load.
You will notice that this minimizes the difference between horizontal construction and the standard vertical setup.
