ᐅ Kallax doors jam due to temperature changes – any experiences?
Created on: 25 Jun 2022 08:37
gjergjli
gjergjli
25 Jun 2022 08:37
I have noticed that the doors of my IKEA Kallax shelving unit tend to stick, especially with larger temperature fluctuations. I mean, when it gets very warm or cold outside, the doors are no longer easy to open – sometimes they become very stiff or even get stuck in the frame. The unit has been in place for several months and has not been moved, but the problem seems to be caused by material expansion and contraction. Has anyone else experienced something similar or knows of solutions to prevent the doors from sticking during temperature changes?
I suspect it might be related to the glue joints or the thickness of the door material, but I’m not sure. I would appreciate exchanging ideas, especially if anyone has practical tips or suggestions for improvement. Thanks in advance!
Repar
25 Jun 2022 09:12
The sticking often occurs due to the swelling of the wood or MDF panels caused by moisture and temperature changes. You can try lightly sanding the doors where they are too tight. The hinges should also be checked and adjusted if necessary.
Otherwise, regulating the indoor humidity a bit can help reduce the effect.
Elodie
25 Jun 2022 10:44
Exactly! And I would also recommend being a bit patient, as wood products naturally react to their environment. 🙂
A small tip from me: If you treat the doors with some wax or furniture oil after sanding, they often slide much more easily again. This also provides good protection against further swelling.
Kallax isn’t the most delicate shelf unit, but the material still changes over time. If the problem is severe, allowing a bit more clearance between the door and the frame might also be helpful.
V
vincent46
26 Jun 2022 07:53
gjergjli schrieb:
Although the shelf has been in place for several months without being moved, the issue seems to arise due to material expansion and contraction.
I totally understand—I went through a similar problem and found it really frustrating when you just want to use the shelf, but suddenly everything gets stuck.
What helped me was readjusting the hinges and slightly pulling the doors out of the frame. It’s not perfect, but it made daily use much easier.
Maybe this will help you too, even though I know it’s a bit annoying to check these things regularly. Hang in there! 🙂
karlau
27 Jun 2022 15:29
Elodie schrieb:
Kallax is not the most delicate shelf, but the material does wear down over time.
Well, I would even argue that the issue is not just the material, but the design. Kallax doors are slim and made of MDF with a laminate coating – this increases the risk of warping due to temperature fluctuations.
Anyone expecting to simply set up a shelf without considering environmental factors might be disappointed here.
I don’t understand why IKEA doesn’t offer alternative solutions. Perhaps thinner backing panels or simply more spacing would help, but cost reduction seems to be the deciding factor.
For those wanting to be on the safe side, it’s better to stick with open versions or use glass doors, which are much more dimensionally stable.
