ᐅ KALLAX Doors Swing Open – Are Dampers Useful?
Created on: 3 Jul 2016 09:02
Avdimu
Avdimu
3 Jul 2016 09:02
I have installed the doors on my KALLAX shelving unit from IKEA for some time now and have noticed that they often close with a fairly loud bang. This not only causes annoying noise but also makes me concerned about the durability of the hinges and the furniture overall.
My question is: Is it advisable to retrofit dampers on the KALLAX doors to prevent slamming? Has anyone experienced whether this investment is worthwhile, how easy they are to install, and if there are better alternatives to reduce wear and tear?
I look forward to your opinions and tips!
meson
3 Jul 2016 09:47
Dampers are definitely useful. They prevent hard slamming and protect the hinges.
Installation is usually simple, often just a click or screws. Just attach them; it’s worth it.
Sinan-meo
3 Jul 2016 10:15
meson schrieb:
Dämpfer sind auf jeden Fall sinnvoll.
I agree with that. Especially with KALLAX, the material is quite thin, and slamming shut can quickly cause damage. Installing soft-close dampers is straightforward; often, only a small adapter is attached to the hinges.
If you really want to reduce noise and wear, dampers are a worthwhile investment.
Tause
3 Jul 2016 10:58
Avdimu schrieb:
I’m concerned about the durability of the hinges and the furniture as a whole.
That concern is valid, as KALLAX is not designed for heavy loads.
However, the question is whether standard hinges already provide sufficient damping. From my experience, cheap dampers can fail quickly or get dirty, which tends to be more of a nuisance. It is worthwhile to invest in good quality and properly adjust the door before adding dampers as an upgrade.
labau
3 Jul 2016 12:03
If the doors really slam loudly, significantly more than usual, then yes, dampers do help.
I used the ones from IKEA myself; they fit perfectly and are quick to install. Nothing complicated.
Renka
3 Jul 2016 16:27
Tause schrieb:
Cheap dampers can fail quickly or get dirty
Interesting point, but I think it is sometimes overstated. Most dampers do exactly what they are supposed to, and dirt buildup can also be prevented.
In my opinion, the slamming is a design flaw in KALLAX, and using dampers only superficially solves the problem. A better door mechanism or different hinges would actually be more sustainable. But of course, who wants to modify something when simple dampers can be used.
