ᐅ KALLAX Converted into a Bench – Issues with Stability?
Created on: 20 Jun 2022 09:14
Mikase
Mikase
20 Jun 2022 09:14
Good morning everyone, I am planning to convert an IKEA KALLAX shelf unit into a bench to use in my entryway. However, I have noticed that its stability seems questionable without additional reinforcements, as the unit was not originally designed to support weight as a seating surface. My specific question is: Has anyone here had experience converting a KALLAX shelf into a bench and can share whether it is stable enough without extra reinforcement? If so, what measures did you take to prevent issues like sagging shelves or wobbly side panels? Are there particular fastening techniques, reinforcement elements, or materials you would especially recommend? I appreciate any advice, especially since I want to use the bench regularly and want to avoid any risk of instability or collapse.
Fitigu
20 Jun 2022 10:03
Mikase schrieb:
is it stable enough without additional reinforcements?
The KALLAX shelving unit is generally designed for light to medium loads but not intended as seating. Therefore, stability without reinforcements is limited. For safe use as a bench, I recommend the following measures: reinforcing the side panels by installing metal brackets or wooden strips, adding extra cross braces beneath the seating area, using stronger screws (e.g., wood screws with a larger diameter), and gluing the joints with wood glue. Additionally, check whether the back panel needs to be removed or reinforced, as it contributes to overall stability. Without these modifications, there is a risk of bending or wobbling, especially with regular use.
farje
20 Jun 2022 10:45
Fitigu schrieb:
For safe use as a bench, I recommend the following measures: reinforcing the side panels by installing metal brackets or wooden strips.
That might be reasonable, but I doubt that the shelving unit with such modifications truly achieves the necessary load distribution of a bench. The original KALLAX frame is made of thin particleboard, which is sufficient for shelves but not for dynamic loads, like those on benches. Therefore, my question is: Are there concrete practical experiences or test results demonstrating that simple brackets or strips are enough, or is a complete rebuild of the carcass with sturdier materials more appropriate? Who actually implements such modifications safely and permanently?
Jensson
21 Jun 2022 08:22
About six months ago, I converted a KALLAX shelf into a bench seat, so I can share some practical tips:
1. Materials and Preparation: The carcass parts are made of rather thin particleboard, which becomes apparent under load. Therefore, the first step I took was to reinforce the inside of the side panels with 12mm (0.5 inch) plywood sheets, which I screwed and glued in place.
2. Cross Beams: Under the seating surface, I added an additional wooden slat running across the entire width—18mm (0.7 inch) plywood in my case—secured to the side panels with strong screws. This prevents sagging.
3. Back Panel: The thin cardboard back panel was replaced with a thin plywood board and screwed in, significantly improving the stability of the structure.
4. Seating Surface: A wooden board was placed on top of the shelf as the actual seat, which I also screwed down. Without this, the existing shelf board alone is too thin to sit on.
5. Screws: Glue alone is not sufficient—the joints must be firmly screwed together. Countersunk wood screws are ideal.
Conclusion: Without these modifications, the stability is far too low for use as a bench. So no, the original material alone is not enough. Anyone attempting this without woodworking experience should at least ensure solid reinforcements.
KINMIN4
21 Jun 2022 09:15
In short: Without reinforcements, the KALLAX hardly holds up as a bench. Install metal brackets on the sides and additional cross braces. Double up the base panel. Then it will be stable.
noge58
21 Jun 2022 10:02
This is really great what’s being shared here! 🙂 I’m planning to turn my KALLAX into a bench as well and now feel truly motivated! Thanks for the tips about the plywood panels and cross braces – I will definitely use them. If that helps, I’ll soon have a really cool and unique seating solution. Looking forward to the result!
