ᐅ Kallax Shelving Unit as a Workshop Shelf and Chemicals – Is It Dangerous?
Created on: 13 Jan 2018 08:23
Sangeorgio
Sangeorgio
13 Jan 2018 08:23
Hello everyone, I am considering using my IKEA Kallax shelf as a workshop storage unit because it fits well visually and space-wise. However, I am wondering if storing chemicals in it could be problematic or even dangerous. Specifically, I mean chemicals like brush cleaners, thinners, various adhesives, and possibly small leftover paint containers.
My concern is whether the Kallax shelf is stable and safe enough for such substances and how these should be stored there to minimize risks like vapors, potential leaks, and even fire hazards. Are there any experiences or recommendations on how to safely convert my Kallax for such uses? Are there special measures or additional equipment that you would recommend if someone wants to store these types of materials in it?
I appreciate any tips, especially if you have practical experience or advice for safely using a Kallax shelf in a workshop!
PEDRO40
13 Jan 2018 12:41
I completely understand you, your concerns are definitely justified.
Sangeorgio schrieb:
whether storing chemicals in there could be problematic or even dangerous
Especially with solvent-based substances like thinner, caution is necessary. I once stored paints and thinner in a Kallax unit without any special precautions. After some time, the fumes slightly damaged the wood and there was a strong odor, which was unpleasant.
Sangeorgio schrieb:
what is stable and safe for such substances and how they should be stored to minimize risks
My recommendation would be to keep such chemicals in airtight plastic containers and to equip the shelving with a fire-resistant base. A closed system for the shelf also helps: doors or at least some dust protection. Ventilation in the workshop is, of course, very important as well.
In my experience, storing all chemicals separately from wood and paper materials also helps to prevent damage and reduces the need for frequent airing to protect those materials. Maybe this helps!
Not perfect, but better than nothing.
LAURE-TA
14 Jan 2018 09:18
Hello Sangeorgio, I think your question is very reasonable, and I would like to give you some structured advice that may help you use your Kallax shelf safely as a workshop shelf for chemicals.
1. Material of the Kallax: The Kallax is made of engineered wood (MDF/particleboard) with a melamine or laminate coating. This surface is not specifically resistant to chemicals. Therefore, thinners, paints, or other solvents can potentially damage the surface and cause the material to soften or deform.
2. Stability: The shelf generally supports loads well, but if liquids leak, the wood can swell and reduce its load-bearing capacity.
3. Storage of chemicals:
a) Always store chemicals in their original, tightly sealed containers.
b) Ideally, place them in additional plastic bins or metal boxes to prevent leaks and evaporation.
c) Do not store flammable materials near open flames or heat sources.
d) If possible, use fire-resistant mats or protective liners under the relevant shelves.
4. Ventilation and odor control: Since Kallax shelves are open or fitted with loose boxes, it is recommended to position the shelf in a well-ventilated room. Alternatively, you can equip the compartments with doors or use curtains to help protect against dust and fumes.
5. Alternative solutions: For truly hazardous or highly flammable substances, metal cabinets with safety certification are better suited. If this is not an option, the Kallax should only be used with less aggressive substances and with caution.
In summary, the Kallax shelf offers a practical solution, but you must take some precautions to avoid damage, health risks, or fire hazards. I hope this helps you!
nofomu
15 Jan 2018 14:09
LAURE-TA schrieb:
MDF/particleboard with melamine or laminate coating is not resistant to chemicals
In short: If you want to store chemicals, only do so in airtight plastic containers and keep the shelf away from heaters or open flames. Otherwise, you risk damage and hazards.
PEDRO40 schrieb:
Airtight plastic boxes and fireproof base as protection
I agree with that. It’s as simple as that.
