ᐅ Using Kallax as a coat rack—how do you set it up?
Created on: 22 Jun 2022 08:27
NODRA65
Hello everyone, I’m considering using my IKEA Kallax shelf as a wardrobe, especially in the hallway area, and I’d like to hear about your experiences with this. I’m thinking of either leaving the compartments open or combining them with inserts and hooks to organize coats, jackets, scarves, and shoes efficiently. However, I’m wondering how you have handled the stability and the attachment of wardrobe hooks to the Kallax—since it needs to be sturdy, particularly when holding children’s jackets or heavy coats. I’m also interested in whether you prefer using the Kallax standing upright or lying down as a wardrobe, and how practical it is in everyday use. How do you do it, and what tips can you share?
lajudo
22 Jun 2022 14:19
To adjust the height, simply place the Kallax on a few wooden blocks. This way, you gain extra storage space underneath, and the hooks will be at the correct height.
Dirkmin
23 Jun 2022 08:45
In summary, when converting a Kallax shelf unit into a wardrobe, the following should be considered: increase the load capacity of the side panels by reinforcing them, ensure secure attachment of the hooks using pre-drilled holes, and anchor the unit to the wall. Organizing the space is easier with suitable boxes or inserts. For different jacket lengths, a combination of side panels with inner hooks and an additional coat rail above the unit is recommended.
NODRA65
23 Jun 2022 09:12
Dirkmin schrieb:
For different jacket lengths, a combination of side trims with hooks on the inside and an additional coat rack bar above the shelf is recommended.
Thank you for the summary, that sounds reasonable. I find the combination of storage and coat rack practical. Does anyone have experience with an integrated seating area in connection with the Kallax used as a coat rack? Could a Kallax shelf also serve as a bench, or would that be too much load?
Leonardteo
24 Jun 2022 10:34
Using a Kallax shelf as a bench is generally possible, but you should reinforce its load-bearing capacity with an additional top cover made of sturdy wood. Relying on the Kallax alone is not sufficient. An extra mounting board on top helps distribute the weight more evenly and provides greater stability. Otherwise, there is a risk that the shelf may sag or become damaged.
bauku
24 Jun 2022 11:00
Leonardteo schrieb:
An additional mounting plate on top distributes the load more evenly and provides greater stability.
That's exactly what I did as well! I screwed a wide OSB board onto the shelf and added a thick cushion. This way, I have a very practical bench with storage, and it looks great 🙂
