I have been looking into the IKEA KALLAX and its durability in everyday use for some time now. Specifically, I wonder: is it really common for a KALLAX shelf to become completely unusable after about five years of daily use and eventually only be fit for disposal?
My question concerns the quality and workmanship of this piece of furniture: can it be expected that the materials – especially the wood-based panels and the gluing – wear out so much over that time that repairing or continuing to use it hardly makes sense? Or is there hope that a KALLAX shelf, with proper care and careful use, can last longer and remain in good condition?
I would appreciate experiences or assessments from people who have been using their KALLAX shelves for many years, including with regard to different stresses (e.g., heavy books, moisture, moving). How durable is this piece of furniture really?
Thanks in advance for your opinions!
Basically: KALLAX is not solid wood but particleboard with a coated surface. This means moisture is the biggest enemy. If you keep it dry, it will last significantly longer than 5 years. Damage usually occurs due to water exposure or overloading. So either handle it carefully or replace it.
gomafar schrieb:
Is it really common for a KALLAX shelf to become completely unusable after about five years of use?Oh no, I hope not! 😉 I’ve had mine for over seven years, and it still looks like new! Of course, no piece of furniture is indestructible, but with a little care and proper use, you can keep your KALLAX for a very long time. Just avoid using it as a plant shelf in the bathroom to prevent moisture damage.
Honestly, with a bit of maintenance and by not constantly moving it around or overloading it, you’ll love your furniture piece! 🙂
RonJarrett24 Oct 2017 13:12Darryl schrieb:
Moisture is the biggest enemy. Exactly. The KALLAX shelves are made of wood-based panels with a laminated surface. This provides some protection against minor damage, but once moisture penetrates, the material starts to swell and loses stability.
gomafar schrieb:
Can it … last longer with proper care and careful use? Yes, that is possible. Handling it carefully, using protective mats, and placing it in a well-ventilated area help.
Additionally, the joining technique of KALLAX, using dowels and screws, is not designed for frequent moving or long-distance transport.
In summary: KALLAX is an affordable, attractive shelving unit, but it is not designed as a long-lasting solid wood piece of furniture. It can last a solid five years or more—provided it is used with appropriate care.
This is amazing, all the things you’re sharing here! 🙂 I’ve had my KALLAX for almost 6 years now – it has a few scratches, but I’m still very satisfied.
My tip: Just dust it lightly from time to time, don’t overload it (max. 10-15 kg per compartment), and try to avoid using the shelf in damp basements or bathrooms. Then it will last forever, guaranteed!
And if you do get glue or black marker on it: Head to the craft area and use fine sandpaper and wood varnish to fix it. 😉
KALLAX is solid and durable!
gomafar schrieb:
Or is it reasonable to hope that a KALLAX shelf, with proper care and careful use, can last longer?Hello!
I can relate to your question, as I have also considered buying a KALLAX for a while.
In summary: Yes, these shelves are generally not built to last forever. The finish and the engineered wood materials used are relatively inexpensive, which affects their durability. After about five years of heavy use, problems can occur, such as sagging shelves or damaged edges.
This mainly concerns three aspects:
1. Load: too many heavy items can cause the shelves to deform.
2. Moisture: contact with water or high indoor humidity can cause the panels to swell.
3. Moving/transport: frequent disassembly can weaken the joints.
What I recommend: If you place the shelf on felt pads, keep it indoors in a room with moderate humidity, and avoid constant overloading, you can definitely enjoy it for more than five years. Also, it’s worthwhile to address visible damage promptly, for example by re-gluing or replacing panels.
In short: It’s not solid wood furniture with a decades-long warranty, but it’s also not disposable. At least you can expand it if needed, easily adjust it, or add new shelving boards.
If you want specific tips on repair or maintenance, feel free to ask!
