ᐅ Is there any Ikea Pax accessory that makes assembly easier?
Created on: 18 Mar 2023 09:23
Chenclaris
Chenclaris
18 Mar 2023 09:23
I’m currently planning to build a complete Pax wardrobe and have already seen that putting it together can take quite some time and effort. Aligning the cabinet frames, attaching the back panels, and fixing the doors seem to be particularly tricky.
Therefore, I’m interested to know if anyone here in the forum is aware of any accessories or tools specifically for the Pax system that make the assembly process more efficient or easier.
Are there, for example, special templates, assembly aids, or improved fittings available, either from Ikea itself or third-party suppliers?
Practical tips or experiences would also be greatly appreciated, especially if they apply to non-professionals without specialist equipment.
Paunon
18 Mar 2023 11:29
Yes, there are some accessories that can help. For example, the "Pax assembly template" is very popular for ensuring doors are properly aligned. Additionally, installation kits with pre-made screws and wall plugs make the work easier. However, a helper or a second person is usually still necessary.
TEOZAR
18 Mar 2023 14:04
I can understand the question well; assembling Pax can be a challenge for many. Although Ikea does not offer specific "assembly accessories" as separate products, there are some tools and approaches that can make the process easier:
- A drilling or positioning jig for aligning the cabinet doors, as Paunon has already mentioned, is helpful. It ensures even spacing and prevents misalignment.
- Use a cordless drill with the appropriate bit, but be careful not to over-tighten the screws.
- For securing the back panels, there are sometimes special battens that increase pressure and help keep everything straight.
It is also recommended to carefully sort all parts before assembly and follow the instructions closely. If desired, I can provide additional tips on how to assemble step by step.
Palenar
19 Mar 2023 08:17
TEOZAR schrieb:
Ikea does not offer any specific "assembly accessories" as separate products, but there are some items and techniques that can make the process easier
That is a very accurate statement. To be more precise: Ikea itself does not sell additional assembly aids specifically for Pax, as is sometimes the case with certain power tools or types of furniture. However, there are third-party suppliers who specialize exactly in this area.
Based on my many years of experience assembling Pax systems, I can recommend:
- Installation templates for doors: Especially with double doors that use hinge mounts, templates can help align the doors precisely. Standardized hole spacing and hinge depths must be observed.
- Magnetic screw holders or small parts containers: These prevent losing important screws, especially since some screws are very small.
- Additional corner brackets: Useful if you want to increase stability without major modifications.
- Adjustable clamps: Ideal for holding components parallel during screwing.
- Leveling feet or shims: Particularly helpful on uneven floors to make assembly much easier.
If you like, you can describe which assembly steps you find particularly difficult. Then I can offer more targeted advice on accessories or methods.
PAREL
19 Mar 2023 12:53
When it comes to the question "Is there Ikea Pax accessory that makes assembly easier?" a structured approach is especially important. Accessories alone don’t help much if the assembly organization is lacking.
Here is a step-by-step guide along with tips and useful aids:
- Preparation: Sort all parts by article number, separate screws by type, and read the instructions thoroughly.
- Assembly templates: These are particularly helpful for door installation and ensure perfect gap measurements.
- Cordless screwdriver with torque control: This allows you to tighten screws precisely without damaging the wood.
- Small screwdrivers or bit attachments: For screws in tight spaces.
- Trial fit: Before fully tightening the screws, assemble everything loosely to align and check positions.
- Stabilization aid: Clamps or straps can hold cabinet parts in place when no second person is available.
- Back panels: These are often difficult to align. A helpful tip is to insert them completely loose at first, then align the frame, and finally secure the back panel.
If you find door alignment or inserting the back panels particularly difficult, there are special brackets and connector clips from third-party suppliers that can significantly ease the work. Some even use simple wooden wedges as a temporary fixing aid.
I would like to know—which assembly steps do you personally find the most time-consuming or tricky in your Pax project?
Chenclaris
20 Mar 2023 10:11
Palenar schrieb:
If you like, you can describe in more detail which assembly steps you find particularly difficult.
Thank you for the detailed advice. Specifically, I am having trouble with door installation, especially with the hinges, and aligning all the cabinet doors so that the gap sizes are correct. I also find attaching the back panels quite tricky because the back panel often doesn’t fit perfectly, and the frame seems unstable as a result.
Additionally, I lack a sense of how tightly I can screw in the screws to avoid damage while still ensuring enough stability.
PAREL schrieb:
If you find door alignment or installing the back panels especially difficult, there are special brackets and connecting clips from third-party suppliers that can make the work much easier.
Could you or others in the forum provide some examples or sources for such practical tools? I am willing to invest in good accessories if they really simplify the assembly process.
Also, how do you handle the issue of screw tightening force? Are there standard recommendations for the torque or force to use? Thank you in advance!
