ᐅ Is there an alternative to the Malm dresser if issues arise?
Created on: 20 Mar 2020 14:17
Coskun
Coskun
20 Mar 2020 14:17
I would like to ask a more detailed question that might be relevant to some of you. My Malm dresser has started to show several issues, both with stability and the drawer mechanisms. I feel that the wood is starting to give way and the drawers are no longer sliding properly – a common problem with older models or frequent use.
So my question is:
Is there an alternative to the Malm dresser for issues related to durability and mechanics, specifically from manufacturers or models that are made with higher quality but without being too expensive? I would like to know if there are furniture options similar in size and appearance but offering better long-term quality, perhaps with sturdier drawer guides and more durable materials.
I’m very interested in your experiences and recommendations, including any tips on what to look for when buying a dresser intended for long-term use that won’t wear out or cause problems after a short time.
Thank you in advance!
Leonardteo
20 Mar 2020 16:45
Hello Coskun,
Your question is indeed very relevant because the Malm dresser is popular and affordable, but it tends to have issues with heavy use. This is mainly due to the MDF wood material and the basic roller drawer slides.
As an alternative, I recommend models with solid wood frames or solid wood fronts, as these are generally more durable. Retailers like Home24 or Poco often offer dressers with more robust drawer runners, such as full-extension slides with soft-close features. Look for metal runners and as thick wood panels as possible, as this greatly improves stability.
If you want something similar in style to the Malm, look for Scandinavian-inspired furniture, often made with oiled or lacquered solid wood, which looks similar but is more durable due to better craftsmanship.
One more tip: check customer reviews carefully, as buyers often report early damage or better experiences with models that appear similar to the one you like. This way, you can avoid poor purchases more effectively.
Renegi
20 Mar 2020 19:03
If you have issues with the Malm dresser with drawers, opt for dressers with full metal drawer slides, as they are more durable.
Choosing solid wood instead of particleboard also helps. Brands like Höffner offer good models in the mid-price range.
LOJOPAR
21 Mar 2020 09:12
I would like to organize this topic from my perspective to provide clear guidance when buying a chest of drawers, especially when the Malm chest falls apart.
1. Material choice:
Particleboard or MDF panels are inexpensive but often show weaknesses under heavy use – warping and damaged drawer runners are common issues.
Solid wood or at least a combination of a real wood frame with high-quality panels significantly increases durability.
2. Drawer slides:
Standard plastic roller runners are prone to problems and do not always run smoothly.
Better alternatives are full-extension metal slides with ball bearings, which often also include soft-close functionality.
3. Workmanship and assembly:
Make sure the chest is securely screwed together and not only assembled with push-fit connectors. Often, “remote-controlled” assembly kits are unstable.
4. Appearance and size:
Keep in mind that a look similar to the Malm usually comes at a higher price if you expect better quality.
Conclusion:
If you are looking for a reliable long-term alternative, you should invest in the areas mentioned above. Models from manufacturers like Musterring or Hülsta offer good quality but are somewhat more expensive.
I hope this helps!
elgla
21 Mar 2020 13:27
Coskun schrieb:
I get the feeling that the wood is starting to give way a bit and the drawers no longer slide properly – a typical problem with older models or frequent use.
I can really understand how frustrating that is. I’ve been there myself – especially when you rely on a piece of furniture so much.
I had a Malm too, which after about 3 years became more of a hassle because it squeaked and the drawers got stuck. By now, I’ve switched to a solid wood product and truly notice the difference – it just feels more sturdy and needs fewer annoying adjustments.
Sometimes it’s also worth paying attention to things like warranties or customer support in case problems arise. For example, Ikea sometimes offers replacement parts, which often helps.
Hang in there, there are definitely alternatives, even if switching feels overwhelming at first. 😉
PERON
22 Mar 2020 08:48
Renegi schrieb:
Full-extension metal drawer slides are more durable.
I agree with that! 🙂
Sometimes with the Malm drawers, it feels like they roll on marbles rather than on proper rails. They have clearly chosen cheaper materials there.
If you want to keep a bit of style, you might also want to look at dressers from the vintage section or small pieces made from solid wood. That not only adds stability but also character to the room.
Good luck with your search, and remember: Expensive doesn’t always mean better, but with dressers, quality definitely pays off if you want them to last longer! ;-)
