ᐅ How do I repair chipped corners on MALM dressers?
Created on: 27 Aug 2021 18:17
Raleman
Raleman
27 Aug 2021 18:17
I have unfortunately discovered chipped corners on the drawer fronts of my IKEA Malm dresser. This is particularly annoying because the edges are the most visible part, and the wood appears to be either painted or laminated. I am now looking for a solution to repair these damaged areas that is as durable as possible, but also easy to do.
Does anyone have experience with discreetly repairing chipped corners like these? What materials and tools would you recommend? Is it better to use putty, wood glue, or special wood repair kits?
It is also important to know whether it is possible to paint or laminate over the repair afterwards, so that it looks reasonably close to the original.
I look forward to your tips and instructions!
pinpa
27 Aug 2021 18:45
Hey Raleman!
I’m very familiar with those chipped corners on MALM dressers! 😊 My advice: first carefully remove any loose paint and splinters, then fill the area with wood filler. There are special repair kits for furniture that include pigments for different colors.
If you let the filler dry thoroughly and then use fine sandpaper (240 grit or finer), you’ll get a very smooth corner. Finally, apply some furniture wax or color-matched paint, and it will look almost like new.
It takes a bit of patience, but it’s worth it! 😉
RETRAVIS
27 Aug 2021 19:02
Regarding the issue of chipped corners on MALM dressers, please note the following:
1. The fronts are usually made of particleboard with a foil or lacquer finish, so repairs without visible differences are challenging.
2. Suitable repair materials include special wood filler or putty based on acrylic or epoxy. Epoxy filler provides better adhesion and durability.
3. Procedure:
- Remove loose parts.
- Lightly sand the surface.
- Apply and shape the filler.
- Sand again after drying.
- Touch up with matching paint or furniture marker.
4. Fully restoring the foil finish is complicated. Usually, a color-matched paint touch-up is sufficient.
For best results, use high-quality materials and work carefully.
LEOIX
27 Aug 2021 19:35
RETRAVIS schrieb:
Complete repainting is complicated.
Well, complicated maybe, but not impossible. If you really want to, you can make the corner almost invisible – with some craftsmanship and the right amount of patience.
I think it’s worth looking beyond just the repair here: why not prevent the damage in the first place? Small protective strips or corner guards can help avoid trouble. But back to the topic – without good paint and filler, the result will just look temporary.
Aimee
27 Aug 2021 20:03
Use epoxy-based filler.
Then sand smooth.
Adjust the color with a furniture touch-up marker.
Works well for chipped corners.
dijan
27 Aug 2021 20:27
I once had the same issue with my MALM dresser. I simply repaired it with wood filler, lightly sanded it, and then sprayed over it with matching paint from the hardware store. Important: be patient, apply several thin coats, and the result will be clean!
And don’t worry, the outcome is better than you might expect. Your dresser will almost regain its charm. 😉
