Hello everyone, I recently bought a few Billy bookshelves from IKEA and plan to place them near a window. Since the shelves are made of particleboard with a laminated surface, I’m concerned about possible UV damage such as fading or yellowing from direct sunlight. My question is: Is there a way to protect Billy bookshelves from UV damage without affecting their appearance or stability? I would like to know if there are practical, proven measures or products that offer reliable protection without having to completely refinish or modify the shelf. Thanks for your experiences and tips!
FARNU schrieb:
Are there special UV-protective coatings or sealants that can be applied without damaging or visually altering the surface?Special UV-protective coatings are mainly used industrially for exterior applications and are formulated to remain transparent while containing UV filters. For interior use and furniture, spray finishes based on polyurethane or acrylic with UV additives are particularly suitable. The challenge with DIY applications is that uneven layers or unwanted chemical reactions can occur, especially on melamine-coated particleboard, because its surface does not absorb paint.
My advice: Test extensively on an inconspicuous area first. If the result is satisfactory, the shelf can be treated with 1-2 thin coats, allowing each layer to dry thoroughly.
Additionally, I recommend regularly rotating the piece of furniture, if possible, so that the same side is not consistently exposed to the strongest stress.
Well, I have always placed my Billy shelves by the window, and so far there has been no fading. I think it also depends on how long and how intense the sunlight actually is. Occasionally dusting lightly, possibly keeping curtains open when the sun is very strong, and otherwise staying relaxed – these pieces of furniture aren’t made of solid wood, so they fade differently. I do like protective films, but when it comes to fading, patience is also an approach 😉
As an additional note: If you want to use films, there are self-adhesive furniture films with UV protection specifically designed for smooth surfaces—these are less likely to form bubbles or have corners lift.
For UV varnish, you can prepare the surface by lightly sanding it with very fine abrasive mesh (careful not to go through the melamine coating), then clean it with a lint-free cloth. This helps the varnish adhere better.
Even if you decide against this, installing window shading (for example, a roller blind) is the easiest way to minimize UV damage, since otherwise the material will always be exposed.
If you need more tips, just ask!
