ᐅ Is it possible to paint IKEA Metod cabinet fronts yourself?
Created on: 23 Feb 2019 09:34
Cornelius8
Cornelius8
23 Feb 2019 09:34
I am planning to upgrade my IKEA Metod kitchen cabinets with new fronts, but I find the ready-made lacquered fronts quite expensive. Therefore, I am interested in practical and sustainable methods to paint the original Metod fronts (e.g., made of MDF) myself, without damaging the surface or compromising durability.
I am particularly curious about which materials and preparations are necessary, whether the surface needs to be sanded before painting, which types of paint are suitable (acrylic, polyurethane, etc.), and the best way to apply the paint. Has anyone here had personal experience with this?
I look forward to any tips, warnings about potential pitfalls, and tricks that can make painting IKEA Metod fronts easier or even professional.
kau56
23 Feb 2019 10:17
Cornelius8 schrieb:
I am particularly interested in which materials and preparations are necessary, whether the surface needs to be sanded before painting, which types of paint are suitable (acrylic, PU, etc.), and how the paint application is best carried out.
Hello Cornelius8,
that is a very good and precise question regarding painting IKEA Metod fronts yourself. Basically, the Metod fronts are usually made of MDF with a thin melamine or polymer coating that needs to be thoroughly sanded beforehand to ensure proper paint adhesion. Important steps are:
- Thoroughly degrease the fronts
- Lightly sand them (with fine sandpaper, e.g., 220 grit)
- Apply a suitable primer (acrylic or PU primer)
- Finally, seal the surface with 2–3 coats of paint
PU paint is very durable, but acrylic paints also work well, especially for DIY projects. Spray application provides the best result, but a good foam roller or a fine paintbrush can also work.
It is important to carry out all work in a dust-free environment and at an appropriate temperature.
I hope this gives you a good starting point!
GIPAPO
23 Feb 2019 11:02
Metod fronts can definitely be painted by yourself. Important:
- Sand thoroughly
- Use a primer
- Apply several thin layers of paint
If you don't have a spray gun, use a foam roller.
Make sure to observe the drying times carefully.
CORYGAU
24 Feb 2019 14:46
kau56 schrieb:
That is a very good and precise question regarding painting IKEA Metod cabinet fronts yourself.
I agree, but you should carefully consider whether the material might be damaged by moisture during sanding or by using the wrong paint.
The original fronts often have a synthetic resin glaze, which is not easy to refinish. Even though polyurethane paint is very durable, professional surface preparation is required; otherwise, the paint tends to peel off easily.
Also, if you are considering environmental factors, you should pay closer attention to the solvents—some paints can be quite harsh. When in doubt, it is better to choose water-based products.
One last point: the edges of the fronts can be more challenging to paint because the paint tends to build up or run there. In this case, either spraying with compressed air or very even rolling helps.
From my own experience, I can say that thorough preparation often determines the success or failure of the project.
tigau
24 Feb 2019 15:29
CORYGAU schrieb:
If you are considering ecological aspects, you should pay closer attention to the solvents – some paints contain very harmful solvents.
Exactly, otherwise you could ruin everything if you don’t consider the solvents.
Otherwise: additional recommendation – always apply a primer! Otherwise, the paint will not adhere properly.
Laurence
25 Feb 2019 08:16
Cornelius8 schrieb:
I am looking forward to tips, warnings about pitfalls, and tricks that can make painting IKEA Metod fronts easier or even professional.
Hello Cornelius8,
I have painted Metod fronts myself using acrylic paint and would like to share a few things that helped me:
- Be sure to remove handles or any other attachments before painting
- Sand using 180-220 grit, not too coarse, to avoid deforming the surface
- Use an acrylic or PU primer, depending on how much time you want to invest and which tools you have available
- Ideally, use a spray gun or at least a high-quality foam roller
- Allow layers to dry thoroughly and lightly wet sand with 400 grit after the first coat
At the end, you can apply a thin sealant to make the surface more durable.
It is a bit of work, but with patience and precision, the results can be really good. Good luck!
