ᐅ Is there a way to make Ikea BESTA units mobile by adding casters/wheels?
Created on: 13 Feb 2022 21:37
sontimHello everyone,
I’m considering how to make the Ikea BESTÅ system mobile, meaning to put it on casters so it can be easily and safely moved around the room. My main concern is stability: it shouldn’t become wobbly or damage the furniture frame. The casters also need to be strong enough to support the weight of fully loaded BESTÅ units. I’m curious if anyone has experience with this and whether there are practical, proven methods to equip BESTÅ furniture with casters safely. Are there special casters that can be attached to the feet, or would alternative solutions be recommended, possibly involving some modification? I would also like to know if this is something that can be done well as a DIY project or if it’s better to use specific accessories or even professional customization.
Thank you in advance for your tips and advice!
sontim schrieb:
making the Ikea BESTÅ system mobile, so that it can be placed on casters and easily and safely moved around the roomI think it is basically possible, but with some reservations: Ikea BESTÅ units are not originally designed for mobility. The question is whether you want to modify the original construction or rather add to it.
A key point is the load capacity of the casters. There are casters rated for 50 kg (110 lbs) or more per wheel, but you need to match the load capacity to the total weight including contents. Stability also depends on how firmly the casters are attached underneath – screwing into the original feet holders or drilling into the bottom edges can cause damage.
Additionally, if you use lockable casters on one side, it reduces the risk of unwanted rolling.
I’m curious: How heavy are your BESTÅ units? How often do you plan to move them? And why do you want to make them mobile? The answers to these questions can help narrow down the best solution.
Simply adding casters is not ultimately stable, especially if the furniture piece is tall and narrow.
theo63 schrieb:
The stability also depends on how securely the casters are mounted underneath – screwing into the actual foot brackets or drilling into the bottom edges can cause damageHello,
I agree with you, stability is the most important factor when adding casters, especially for BESTÅ units, which are not originally designed as mobile furniture. Below, I have outlined a simple approach on how to safely add casters to BESTÅ:
- Material selection: Use locking double-wheel casters made of metal or reinforced plastic, with a load capacity of at least 40 kg (88 lbs) per caster.
- Installation: Remove the original feet and replace them with special caster brackets that have sufficient attachment points. If drilling is necessary, pre-drill carefully to avoid splitting the material.
- Caster placement: Mount them as far to the outside as possible to reduce tipping risk.
- Reinforcement: Consider adding an internal cross brace or metal angles to better distribute the load on the casters.
Summary: Yes, you can make BESTÅ mobile with casters if you ensure all fixings are secure and the weight is well distributed. My recommendation is to start testing with fewer casters and avoid experimenting on critical furniture pieces.
If you like, you can send me more details, and I can provide a more precise installation guide.
I would like to go into more detail on this topic because simply attaching casters to furniture like the Ikea BESTÅ system actually presents several challenges.
First of all: The BESTÅ system is usually made of particleboard and plastic connectors, which must be taken into account when modifying it. Directly screwing casters onto the feet or side panels, which are not designed for this purpose, can cause the following issues:
- Material fatigue: The screw connections in the thin particleboard can loosen or tear.
- Tipping risk: BESTÅ units are usually taller than they are wide, which means that casters could cause the furniture to tip over when moved if the casters are not sufficiently stable and lockable.
My suggestion is therefore a combination:
1. Attach a continuous support plate (e.g., a sturdy MDF board or thin plywood) under the entire base area to distribute the load.
2. Screw suitably robust casters (at least 50 kg (110 lbs) load capacity per caster) to this plate. The plate can be optimally fixed to the carcass with screws to distribute the load over multiple points.
3. Select casters with a locking feature to prevent unwanted rolling.
Additionally, be careful that the caster height is not too tall to maintain the appearance and avoid making the furniture too unstable. Precise positioning is important: mount the casters near the corners, not too far inside or outside, to control the torque effectively.
Another point: Depending on how your BESTÅ is constructed (e.g., number of compartments, door weight), you may need stabilizers inside the carcass, such as additional bracing, to prevent twisting from movement. It would be helpful if you could provide more exact measurements and possibly weight details.
Question for you: How do you plan to install the casters? Do you want to mount them on the feet, directly on the carcass, or build a substructure in between? Also, what will you mainly store inside—books, decorations, or heavy equipment? The required measures vary significantly depending on the load.
