ᐅ Is there a way to assemble the IKEA Brimnes furniture more quickly?
Created on: 8 Feb 2024 18:37
NolireHello everyone, I’m about to assemble an IKEA Brimnes piece of furniture and would like to know: Is there a way to make the assembly process faster and more efficient without compromising stability or quality? I’ve already skimmed through the instructions, but they seem quite detailed and somewhat confusing at times. Maybe you have tips or tricks from your own experience on how to avoid common pitfalls and work more quickly. I’m especially interested in advice on preparation, tool selection, and any helpful shortcuts during the process. Thanks in advance for your recommendations!
It’s best to sort all the parts before starting and have them ready according to the instructions. For the Brimnes, you really only need a Phillips screwdriver – I wouldn’t recommend using a cordless drill to avoid over-tightening. Avoid doing multiple steps at the same time, as that only leads to confusion.
I recommend the following structured approach for assembling the Brimnes:
- Preparation: Sort all screws and wooden parts and check them against the parts list in the instructions. This will help avoid troubleshooting during assembly.
- Tools: Use a medium-strength Phillips screwdriver; power drivers should only be used with experience and care.
- Step-by-step: Always assemble all parts of one step first before moving on to the next to ensure a secure fit.
- Tips: Do not fully tighten individual screws at first; just start them to allow for proper alignment in later connections.
A common mistake is tightening everything immediately and then realizing that parts do not fit correctly. This unnecessarily extends the assembly time.
I recently assembled the Brimnes and can say: preparation is half the battle! 😄 Sort all screws and components according to the instructions – this will save you from annoying searching later. Also, if you don’t have a cordless drill, that’s not a problem; the most important thing is that the screwdriver feels comfortable in your hand. I always say it takes six hands in case of emergency – just kidding! But sometimes it’s worth having someone to help; it also speeds things up. And if you sing while assembling, it just goes even better 😉
mauka schrieb:
And if you sing while building, it works even better 😉Music often helps to stay focused and work efficiently. However, the priority should be a clear sequence of steps, not rushing.
PeoDaniel9 Feb 2024 07:26Hello, I would like to expand on Nolire’s question and offer some guidance: When assembling the IKEA Brimnes, it is really important to take your time reading the instructions, even if it initially feels like it slows you down. Here are a few additional tips that can help you work faster while still ensuring quality:
- Group components logically (e.g., all screws for the carcass, all screws for the fronts).
- Attach the back panels last to maintain flexibility when fitting other parts.
- Use clamps, if available, to hold wooden parts in place while screwing — this makes alignment easier.
- Take a close look at all connection points beforehand, as some can be surprisingly tricky.
Overall, it’s not just about speed, but also about avoiding mistakes that could lead to extra work later on.
