ᐅ Is there a step-by-step guide for assembling IKEA Metod corner cabinets?
Created on: 22 Sep 2020 18:37
FibigauHello everyone,
I recently started assembling an IKEA Metod corner cabinet and I’m wondering if there is a genuinely useful step-by-step guide that specifically covers the complete assembly of the corner cabinet in detail.
I’m not referring to a general assembly manual for Metod cabinet parts, but rather instructions tailored precisely to the special features of a corner cabinet – for example, how to properly align the hinges, plan the cabinet carcass cuts for the corner, and whether there are any special tips to keep in mind during screwing and final assembly.
Does anyone have experience with this or know of a guide that systematically and smoothly walks you through all the assembly steps? I definitely want to avoid ending up with an unstable or misaligned corner cabinet, so a structured approach is very important to me.
Thanks in advance for your advice!
Hello Fibigau,
regarding your question about a step-by-step guide for assembling IKEA Metod corner cabinets, I can share the following based on my own experience:
Basically, IKEA provides an assembly manual for the Metod system components, but it is quite general and does not always cover the specific challenges of a corner cabinet in detail. Especially with corner cabinets, it is important to follow the correct sequence and pay attention to the precise alignment of the side panels as well as the correct connection angle.
Here is a rough sequence of steps that has proven effective:
- First, sort all the required parts and check for completeness.
- Pre-drill the cabinet side panels (often pre-drilled holes are provided, but check their dimensions carefully).
- Attach the corner connector plates; proper alignment here is crucial to avoid later issues with the doors.
- Fix the back panel, as it provides stability to the cabinet; for the corner cabinet, make sure to cut it precisely to fit (unless IKEA provides the exact measurements).
- Install the doors with hinges, initially leaving the hinge fixings loose and adjusting them gradually.
- Make precise adjustments to the doors in both open and closed positions, since small angular deviations can quickly cause binding.
It should be noted that IKEA Metod components often use dowels and locking cams, which require a certain level of accuracy in alignment. I recommend using a spirit level and an angle meter where possible.
A few additional tips:
- If possible, have two people assemble the unit—especially when joining the heavy corner elements.
- Do not fully tighten screws immediately; do so only after everything is correctly aligned.
I’m wondering whether you have the corner cabinet as a complete set or if you are combining individual Metod elements yourself? This also affects the instructions and difficulty level.
I hope this helps so far. If you like, I can try to provide a more detailed step-by-step overview.
PLOMA schrieb:
Pre-drill the carcass side panels (often there are pre-made holes, but check their positions carefully).This is the most important point when assembling a corner cabinet. If the holes are not accurate, the doors will jam or the angle won’t fit properly.
And: Always assemble loosely first, then align everything before tightening all screws.
In addition to the previous explanations, here is a structured overview that I believe is well thought out and easy to follow:
- Preparation: Check all parts for completeness and damage.
- Basic assembly: Secure and align the cabinet sides, as some models may have slight variations.
- Connecting the corner modules: IKEA uses special corner connectors that must be installed correctly and precisely (usually metal plates with screws).
- Attaching the back panel: The back panel reinforces the structure and ensures squareness. For Metod corner cabinets, it may be divided, so align it carefully accordingly.
- Installing the doors: Hinges should initially be mounted loosely. After aligning the doors on the cabinet carcass, proceed with final fixation.
- Adjustment: It is very important to adjust the doors on all axes (vertical, horizontal, depth) so they close cleanly and do not rub.
Practical tip: Check the angle once with a carpenter’s square and then double-check. It is also recommended to work on a level, sufficiently large workspace.
If needed, I can provide a detailed step-by-step list including handling tips for the individual components.
PLOMA schrieb:
I’m still wondering whether you have the corner cabinet as a complete set or if you’re assembling individual Metod components yourself?Thanks for the detailed feedback, PLOMA. I’m actually putting together individual Metod components because I planned the dimensions and interior layout myself. So it’s not a plug-and-play set, but rather a modular assembly.
In this context, I’m also wondering if there is experience with aligning the corner joint when cabinets of different depths are connected – for example, a 60cm (24 inch) deep cabinet meeting a 37cm (15 inch) deep corner cabinet. I assume special care is needed when installing the joining plates and the back panel, right?
Additionally, I’m interested if you have any specific advice on the assembly sequence (e.g., starting with the deeper cabinets, first aligning the corner section, or attaching the front doors) that minimizes potential errors.
Looking forward to any further tips!
