ᐅ Is there a guide for reinforcing Ikea Platsa shelves?
Created on: 25 Aug 2021 17:23
Kensi56
Kensi56
25 Aug 2021 17:23
I have a rather specific question regarding the Ikea Platsa furniture series, particularly the shelves, meaning the shelf boards or panels. As is well known, these are not very solid and have a certain flexibility, which can cause sagging on wider shelves when storing heavier items.
Therefore, my question is: Is there a reliable and understandable guide or proven method to reinforce the Platsa shelves? I am thinking of practical solutions that might involve additional supports from underneath, modifications during installation, or other technical measures.
It is important to me that the procedure is safe, significantly improves stability, and ideally does not require overly complicated modifications. I would be very interested in experiences, illustrated step-by-step guides, or specific material recommendations.
Thank you in advance!
REOHEINRIC
25 Aug 2021 18:07
Kensi56 schrieb:
Is there a reliable and clear guide or a proven method for specifically reinforcing Platsa shelves?
Basically, Platsa shelves are made of medium-density fiberboard (MDF), which has a limited load capacity. To reinforce these shelves and prevent sagging, there are several effective approaches:
- Adding support strips made of solid wood or aluminum underneath the shelf panels. These act like beams to reduce bending stress.
- Using an additional thin plywood sheet under the shelf, secured with screws, to increase overall stiffness.
- Installing metal brackets or clips on the sides to fix and strengthen the shelf to the side panels.
A step-by-step guide would be:
1. Remove and clean the shelf.
2. Cut suitable strips (e.g., 20x40 mm (0.8x1.6 inches)).
3. Attach the strips under the shelf with wood screws.
4. Reinstall the shelf and check for stability.
These methods are simple to implement without fundamentally altering the shelf structure. It is important not to use materials that are too heavy to avoid significantly increasing the overall weight.
I hope this helps.
ANMARCOS
26 Aug 2021 09:34
REOHEINRIC schrieb:
Support structure with reinforcement strips made of solid wood or aluminum on the underside of the shelves.
I wonder if it might make sense to address the issue more fundamentally during the furniture design phase. If someone is going to use a Platsa shelf to carry heavy loads, perhaps they shouldn’t expect it to perform like a heavy-duty shelving unit, right?
That said, when it comes to solutions: reinforcement yes, but why always so conventional? Using metal profiles or even carbon fiber inserts could theoretically offer better results, especially if you’re willing to experiment a bit.
Here’s how I see it: IKEA operates on a specific pricing model and mass-produces its products. If you need more durability, you either have to reinforce it yourself or opt for more expensive furniture. Still, I find it interesting how the functionality can be improved with relatively little effort – but always with a balanced approach.
For those who prefer convenience, following the usual advice is probably best, but innovations in reinforcement aren’t seen very often yet – that would be an interesting project.
PAR63
26 Aug 2021 12:51
Kensi56 schrieb:
It is important to me that the method is safe, significantly improves stability, and ideally does not require overly complicated modifications.
Here is a practical guide that I have recommended to several users:
- First, measure the exact size of the shelf board.
- Obtain solid wood strips (for example, spruce or beech) with a cross-section of 20x40 mm (0.8x1.6 inches).
- Cut the strips to the length of the shelf.
- Attach the strips to the underside of the shelf board using wood glue or screws (depending on the material, preferably screws into pre-drilled holes)—ideally in the middle to minimize sagging.
- The screws should not be too long to avoid damaging the veneer on the top surface.
- Then reinstall the reinforced shelf.
This works very well, is easy to follow, and requires no special tools other than a drill, wood drill bit, and screwdriver. It significantly increases the load capacity, almost doubling it compared to without reinforcement.
As a tip: instead of glue, small metal angle brackets can also be added if additional lateral stability is desired.
Good luck!
