ᐅ Is it advisable to use only a small amount of wall tiles in bathrooms and toilets?
Created on: 20 Dec 2023 09:52
netzplan
We are currently selecting our floor and wall tiles. At first, I thought we would only fully tile the shower area / shower niche on the walls.
I was planning to just plaster the toilet area and the washbasin to make it feel a bit more homey, even though the bathroom isn’t really a place where you spend much time sitting :-)
1. What do you think about this? Would that be too daring? Would it be better to have the toilet and washbasin areas tiled as well, about 1m or 1.2m (3.3 ft or 4 ft) high?
2. If we do tile the toilet and washbasin areas, should we also tile the side wall of the toilet area? Please see the sketch.
Grundriss: Flur, Bad, WC, Abstellraum, Haustechnik-Schächte, farbige Markierungen.
netzplan
28 Dec 2023 21:07
Over Christmas, I took a closer look at the flooring at some friends’ place. Yes, that’s actually true. One of my friends had 60x60 cm (24x24 inches) tiles in the guest bathroom. Two full tiles and a narrow strip fit in there. If you pay attention, it really stands out. I took photos for my wife and will ask her if 80x80 cm (32x32 inches) tiles are really a good idea and whether such a narrow strip would bother her.
X
xMisterDx
29 Dec 2023 18:39
For an 80x80 tile, in a small room, you would naturally place a full tile in the center and then have two equally sized strips on the left and right sides... not two 80x80 tiles and a small narrow strip on either the left or right, unless a cabinet or something similar will be placed there anyway.
1 Jan 2024 10:11
netzplan schrieb:
She wants tiles as large as possible, with almost no grout lines (so rectified)
That’s why the advice was:
A grout joint grid of 80cm (31.5 inches) edge length is already a heavy hitter that can visually kill a room.
Your wife’s wish is a current classic, but it can ruin the floor.
netzplan schrieb:
Then it depends on who is more dominant in the conversation 🙂
I would let expertise win 😉
netzplan
14 Feb 2024 22:52
I would recommend consulting an expert
Status: We had the tiling done in the first of the four bathrooms. We chose the smaller sizes, 60cm x 60cm (24in x 24in). However, it must be said that in some areas, 75cm x 75cm (30in x 30in) or 80cm x 80cm (32in x 32in) tiles would have been much more practical because of the grout pattern.
For the living area, we are still debating whether to go with vinyl or tiles. We have also come across DryTile tiles (floating installation). Has anyone had experience with those?
