ᐅ IKEA Metod: How do I install soft-close drawers?
Created on: 4 Feb 2020 09:23
lekimar
lekimar
4 Feb 2020 09:23
I recently purchased an IKEA Metod kitchen unit and am now facing some challenges with installing the soft-close drawer mechanism. Specifically, I would like to know how to properly install the drawers so that the soft-close function works perfectly and the drawer closes smoothly.
I have already reviewed the instructions but find some steps and the alignment of the dampers a bit unclear. Are there any special tips or tricks that could make the installation easier?
I would appreciate advice on installing the drawer slides, correctly adjusting the soft-close mechanism, and what to pay particular attention to in order to ensure quiet and reliable closing.
Thank you in advance!
lalutau
4 Feb 2020 11:37
regarding your question about installing the IKEA Metod drawers with soft-close mechanisms, I can say the following:
- First, it is important that the metal runners on the cabinet side panels are mounted at exactly the same height and parallel to each other. Deviations here will cause problems when inserting and closing the drawer.
- The soft-close units are usually attached to the rear part of the runners. They ensure the drawer closes smoothly and quietly.
- When inserting the drawer, make sure the plastic clips of the drawer runner snap into place. An audible click confirms correct installation.
- If the soft-close does not work properly, it is advisable to check the alignment and make slight adjustments using the adjustment screws, if available.
- It is also important not to overload the drawer, as this can prevent the soft-close mechanism from functioning correctly.
I hope these points help you.
dijan
4 Feb 2020 12:45
Hello! 😄
I know these small plastic dampers can be quite fiddly – it almost feels like working under a microscope! 😂
What I’ve learned is to carefully check where the little damping wheel is positioned. It needs to be placed so that when you close the drawer, it touches the moving part of the slide and slows it down. If it’s positioned incorrectly, you’ll get rattling or the drawer might slam shut.
Tip: Slowly push the drawer into the slides until you feel a slight resistance – that’s exactly where the damping mechanism engages! If you move it back and forth a bit and nothing happens, the alignment isn’t correct.
Oh, and if you need to press or pinch something in place at times – don’t worry. That’s normal until everything fits properly. 👍
BeAndrea
5 Feb 2020 08:14
Hello lekimar,
I can understand your uncertainty, as installing the drawer slides with soft-close mechanisms can sometimes be a bit tricky, especially with METOD. Here are a few basic tips that might help you:
- First, check whether all parts are complete and that the soft-close unit isn’t damaged.
- For IKEA METOD, there are rails with automatic soft-close built in, which are designed to be positioned toward the back of the rail. The soft-close activates automatically when the drawer is nearly closed.
- For the soft-close to work properly, the rails must be installed perfectly level. Use a spirit level to verify this.
- It’s also important to correctly hang the drawer. The plastic clips on the underside of the drawer should click firmly into place.
- If the soft-close doesn’t function as expected, try removing the drawer and readjusting the rails.
If you like, I can also walk you through step-by-step instructions from the manual—just let me know!
Good luck!
lalutau
5 Feb 2020 10:05
BeAndrea schrieb:
Here are some basic tips that might help you:
Exactly, especially the emphasis on mounting the rails perfectly horizontal is crucial. Only if the alignment is correct can the integrated soft-close mechanism work properly.
Also, make sure the rails are not bent before installation. This often happens during transport or if they were stored incorrectly. Even a small bend can cause the drawer to not slide smoothly.
Another point: don’t overtighten the screws on the rails, as this can make fine adjustments difficult. It’s better to check again after assembly and, if necessary, adjust slightly.
In summary:
- Check rails for damage
- Mount rails horizontally and parallel
- Snap plastic clips into place
- Do not overtighten screws
These are the conditions needed for the soft-close mechanism to function properly.
barsar
6 Feb 2020 14:18
In short: The damping is located at the back of the rails, the rails must be exactly parallel and level, and the clips should snap in audibly – then the damping works. If it malfunctions, usually realigning the rails fixes the issue.
