ᐅ IKEA Metod: How can I build cabinets with soft-close doors to be stable and sturdy?
Created on: 24 Sep 2015 08:47
PAUUS
Hello everyone, I am currently assembling several IKEA Metod kitchen cabinets with soft-close doors and am encountering stability issues. Especially with larger cabinets, I notice that the doors do not close firmly and securely despite the soft-close mechanism, and the entire structure sometimes feels a bit wobbly. I have already made sure to position the cabinets precisely at right angles and tighten all screws properly, but that does not seem to be enough. Therefore, my specific question is:
From your experience, what steps are essential to assemble IKEA Metod cabinets with soft-close doors in a way that ensures they stand securely and the doors close perfectly? Are there any special techniques, reinforcements, or adjustment tips that should definitely be considered? I want to avoid the doors becoming too loose or misaligned over time, which would reduce the comfort of the soft-close system.
I look forward to your well-founded advice!
Great topic! Soft-close doors are truly valuable – as long as they are mounted securely :-)
Here’s another tip from me: when assembling, I always use small wooden wedges to position the doors at the exact height while screwing them in. This helps avoid the need for later adjustments and prevents misalignment.
I also recommend not tightening the screws too much in the cabinet sides, as this can compress the material and actually weaken the structure.
Additional stability can be achieved by mounting the cabinet to the wall at multiple points. This way, the whole assembly has better support, and the doors close precisely.
janeo schrieb:
Maybe IKEA itself should recommend how to reinforce the side panels with additional battens if needed.Thank you for the critical remark! That’s exactly what I was thinking as well. The back panel is thick enough, but the side panels seem comparatively thin and bear quite a load due to the weight.
I will check if the side panels can be reinforced with wooden battens at the corners.
If anyone has concrete recommendations for such reinforcements – for example, material thickness, installation locations, or sources – I would be very grateful!
For me, stability is not just about comfort but also safety, as we have small children.
