ᐅ Installing IKEA Metod Baseboards Cleanly and Easily
Created on: 2 Feb 2020 09:17
torsten6
I plan to install the baseboards for my IKEA Metod kitchen system. My main goal is to attach the baseboards cleanly and without major issues. My question is: What is the best way to mount the Metod baseboards to avoid unsightly gaps or loose fittings, and to ensure a secure attachment even on uneven floors? Are there any specific techniques or tools that have proven effective? I have some experience with DIY projects, but I really want to avoid mistakes with the baseboards because any imperfections are quickly noticeable. Thanks in advance for your tips!
nubar
2 Feb 2020 13:11
torsten6 schrieb:
How can I best check for unevenness in the floor? Is a simple spirit level enough, or should I use something else?
A spirit level is usually sufficient, ideally a longer one so you can cover larger areas. Move the level to different spots and mark the highest and lowest points. This way, you get a good overview of the unevenness.
torsten6 schrieb:
And what is the maximum gap allowed between the floor and the baseboard to still look acceptable?
I recommend a maximum gap of 5 millimeters (0.2 inches). Any larger is visually too noticeable and can cause issues with clip installation.
glamo8
2 Feb 2020 14:17
Basically, you should install the clips so that the baseboard floats just above the floor. A gap of 3 to 4 mm (approximately 0.1 to 0.15 inches) is optimal to prevent the baseboard from scraping while still ensuring a neat appearance.
LANICOLE
2 Feb 2020 15:29
A small addition: If your floor has significant unevenness, you can use mounting wedges made of wood or plastic to align the clips accordingly. This will save you from having to do rework on the baseboard later. Also, avoid pressing down too rigidly, as this could damage the clips.
torsten6
2 Feb 2020 16:40
Thank you for the feedback! Another question is whether anyone has experience with trimming moldings around doors or irregular walls. How can one avoid large gaps or uneven joints? Are there any special techniques, especially for inside corners?
LANICOLE
2 Feb 2020 17:02
torsten6 schrieb:
Are there any special tips, especially for inside corners?
Yes, for inside corners it is advisable to leave small gaps because walls are rarely perfectly square. Cut the molding slightly shorter at the corner and fill the small gap with color-matched acrylic sealant. This creates a clean and flexible finish.
You can also use a miter saw with an adjustable angle to fit the moldings precisely.
Mariah
2 Feb 2020 18:37
Walls and corners are rarely perfect, so don’t worry about small gaps. When working with acrylic, the result often looks almost intentional – like a “deliberately transparent design” effect. 🙂
A little flexibility during installation can even help create a harmonious appearance.
