tobi77_876721 May 2016 23:57Hello,
I have installed the Maximera double drawer system, meaning two drawers behind a 60x20 cm (24x8 inch) front (see photo). The upper drawer is set back. However, the soft-close damper does not fit on it anymore. As a result, it always closes very abruptly and quite loudly, which is rather unpleasant. The lower drawer has a damper and works perfectly.
Is there no soft-close option for staggered drawers, or did I install the system incorrectly?
Regards,
Tobi
Regards,
Tobi
IKEA-Experte22 May 2016 00:05Hello, a picture showing the rails would be more helpful.
Do you still have the cover caps on the wall mount?
tobi77_876722 May 2016 00:24.. the problem has already been resolved, the dampers actually fit after all.. I was just too clueless...
however, the two front panels now bump into each other when closing..... do these small adhesive pads help? There are 2 left.... on the back of the front panel?
and you can't install a handle on the top front panel either, right?
