ᐅ IKEA Malm Furniture Scratched – How Can I Repair It?
Created on: 13 Jul 2024 16:42
roju64
roju64
13 Jul 2024 16:42
I have an issue with my IKEA Malm furniture, specifically with the surfaces. Unfortunately, some areas are scratched, which looks especially unattractive on the lighter finishes. Since I can’t simply replace the furniture and would prefer to try fixing it myself, I’m looking for proven methods to repair or at least conceal scratches.
Do you have experience with repair kits specifically for Malm furniture or tips on using household remedies? How much effort is realistically required, and what kind of results can be expected? It would also be helpful to know how to deal with small scratches and the best approach for larger damage.
Thanks in advance for your help!
Dilen
13 Jul 2024 17:21
Hello roju64,
Your concern is very understandable, as Malm furniture usually consists of particleboard with a thin melamine or lacquer coating, which can appear easily damaged when scratched.
There are several approaches to repair:
1. For light scratches: Special marker pens (also called furniture touch-up pens) that closely match the surface color are ideal. It is important to apply a few thin layers and then gently polish with a soft cloth.
2. For medium scratches: Repair wax in stick or paste form can be used. The wax is pressed into the scratch with a spatula and smoothed after drying. Often the color can be mixed to better match the furniture tone.
3. For deeper scratches or chips: This requires more effort. It is best to use a small amount of wood or plastic filler (depending on the furniture material), smooth it out, let it dry, then carefully sand and color match.
Important: Before any repair, clean the furniture thoroughly, as dusty or greasy surfaces reduce adhesion.
One more tip: When working on larger areas, always work in well-ventilated rooms and test the products on an inconspicuous spot first.
How deep exactly are the scratches? Are they mostly superficial, or is part of the coating completely detached?
Maria35
13 Jul 2024 18:08
Dilen schrieb:
For light scratches, special marker pens are ideal
I completely agree. I would like to add that IKEA also offers repair kits specifically designed for Malm furniture, with colors matched to the pieces. These kits often include markers, wax, and instructions on how to best treat different types of scratches.
I would advise against using home remedies like walnuts or shoe polish – while they might temporarily hide scratches, they often leave unsightly marks or cause uneven surface changes.
I recommend trying the repair kit or furniture touch-up marker first, and if the result is not satisfactory, move on to wax or filler products.
Additionally, a very fine polish using microfiber cloths can help achieve a good final finish.
How large and deep are the scratches exactly? For very minor scratches, sometimes a thorough cleaning combined with furniture oil is enough.
lyndon
14 Jul 2024 07:59
The previous answers are all very well-founded. I would like to add that when repairing melamine surfaces – such as those on Malm furniture – caution is always necessary, as they are very sensitive to strong solvents.
A specific tip: For very light surface scratches, first use fine sandpaper with a grit of 1000 to 1200, very carefully and only on the affected area. Afterwards, you can touch up with a suitable furniture repair pen.
Some also recommend very light sanding followed by applying clear varnish, but this is only suitable for experienced DIYers.
If you want to be on the safe side, using a professional repair kit with instructions is the best option. Most hardware stores and also IKEA itself carry such kits.
warrenka57
14 Jul 2024 10:33
I am very familiar with this issue and can say from personal experience that it’s worth not stressing too much about it. Malm furniture is affordable, but you want to use it for a long time without constantly getting frustrated over scratches.
Maria35 schrieb:
I would advise against home remedies like walnuts or shoe polish
I agree with that! I tried it once but was very unhappy with the result – it quickly looked unprofessional.
My advice: take your time and try repair wax. It can be a bit sticky to work with, but when applied carefully, it fills larger damages very well.
Patience also pays off. Sometimes you need to apply several layers and let them dry well in between.
If you like, I can share the exact products I used.
KNUTGI
14 Jul 2024 12:07
Hello roju64,
In my household, the Malm furniture is constantly in use, and I’ve often noticed scratches as well – obviously annoying if you don’t do anything about it 😉
A little life hack from me: For very small, surface-level scratches, I sometimes use a pencil in a matching color. It’s not perfect, of course, but it works okay for a quick fix.
warrenka57 schrieb:
My advice: Take your time and try the repair wax.
Absolutely, it requires patience! Then polish the area afterwards to restore its shine.
If you enjoy the process, you can also apply acrylic paint in a matching color very thinly with a soft brush and blend it out – it looks better than you might expect. Still, be careful, especially with light colors.
Good luck, and don’t lose heart – these kinds of furniture can be surprisingly well restored! :-)
