we are currently planning and building a new kitchen – the Faktum model.
I have about 3.5 m (11.5 ft) of countertop with a Domsjö sink in the middle and above that, five long wall cabinets. For the look (all high-gloss white), there will also be a panel below the wall cabinets as well as on the sides and top to create a framed appearance.
Which spotlights or lights can now be installed under the wall cabinets so that
A) they don’t look awkward
B) the countertop is well illuminated?
I still know the Grundtal spotlights, but they were quite noticeable and a bit tricky to wire because the cables always had to go inside the cabinets.
With Metod and others, I believe there are now new options?
The second topic: I have three base cabinets with clear glass display doors that I want to have interior lighting in. Naturally, it should be subtle but also evenly lit. What would be the best lighting solution for this?
assamerer24 May 2014 09:20See if you can still get the old light panels. However, I can't say if they will fit into the elongated ones.
For these, the cabinet shelf is removed and the panel is inserted. Ideal combination with display/glass doors.
